Hy everyone ..
I want to observe the signal from the SDRAM controller. I read/write it from NIOS II. I was using the advanced triggered with az_cs , az_rd_n , and az_wr_n for as the triggered signal , but I got this error (*attached picture). Does anybody know what is the problem ? learning source : ftp://ftp.altera.com/up/pub/tutorials/de2/digital_logic/tut_signaltapii_verilogde2.pdf Thank you in advance, Yuyex:oLink Copied
I got the problem on the EDGE & Level Detector things..
I set: 1. az_cs edge detector = R 2. az_rd_n egde detector = F 3. az_wr_n egde detector = F why there's a problem with that ?? FYI, I am using SOPC's sdram controller. Thank you- Mark as New
I got the same problem with the edge & level detector.
I was trying the Tutorial "signaltap ii with vhdl designs (ftp://ftp.altera.com/up/pub/tutorials/de2/digital_logic/tut_signaltapii_vhdlde2.pdf)" but at point 4.2 I get also the "Invalid advanced trigger condition expression" message. Without the edge & level detector the .stp file can be saved without this errormessage. I'm using Quartus II v.10.1 Web Edition. Is there a solution for this problem?
Topic Options
