I have been trying to reconfigure for couple of days now and i failed horribly. I am hoping you will shed some light to my doubts; I have been following documentation for trying to reconfigure my PLL; 1. http://www.altera.com/literature/ug/ug_altpll_reconfig.pdf 2. http://www.altera.com/literature/hb/cyclone-iv/cyclone4-handbook.pdf 3. http://www.altera.com/literature/an/an507.pdf ( I understand that this is a tutorial for cyclone III device, but i figured the procedure will be the same because this is the only procedure i found that shows how to configure the PLL. All the other documents just gives reference info but no instructions.) currently my PLL is configured as following; inclock - 50 MHz C0 - 7.5 MHz C1 - 0.004 MHz I created a ill reconfiguration module and connected the ports as shown in either of document 1(page 13 figure 9) and document 3(page 3 figure 2) The All the inputs for the reconfiguration module is coming from my NIOS processor(write_param, read_param etc etc..) Inclock for PLL reconfiguration module is 50 MHz and reset comes from a push button KEY[0] *********************************************************************************************** This is how the program flows *********************************************************************************************** When the program starts, i generate two clock cycles C0 and C1 operating at 7.5 MHz and 0.004 MHz respectively after about 10 sec, i want the clock frequency of C0 to change to 7.0 MHz and after another 10 second, i want my C1 clock frequency to change to 0.005 MHz. Following is a snippet from my NIOS II code;#include "includeme.h"
# include "piodriver.h"
int main()
printf("Hello from Nios II!\n");
// This is the first 10 sec delay
usleep(10000000);
// Set counter type to C0
output_data(COUNTER_TYPE_BASE, 0x4);
// Set counter_param to bypass(4'b0100)
output_data(COUNTER_PARAM_BASE, 0x4);
// Set data_in to 1
output_data(DATA_IN_BASE, 0x1);
// Assert high for 10usec
output_low(WRITE_PARAM_BASE);
usleep(100);
output_high(WRITE_PARAM_BASE);
usleep(100);
// Assuming busy is high at this point for 100ms
// Busy will be alot less then this, but i used 100 just to be sure
usleep(100000);
//output_high(RECONFIG_BASE);
//usleep(10);
//output_low(RECONFIG_BASE);
// Set counter type to N
output_data(COUNTER_TYPE_BASE, 0);
output_data(COUNTER_PARAM_BASE, 4);
// Set data_in to 1
output_data(DATA_IN_BASE, 50);
usleep(100);
usleep(100);
usleep(100000);
//usleep(10);
usleep(100);
// SET COUNTER_TYPE TO M
output_data(COUNTER_TYPE_BASE, 1);
// Set data_in to 1
output_data(DATA_IN_BASE, 7);
usleep(100);
usleep(100000);
// Finally reconfigure the PLL
usleep(100);
printf("RECONFIG COMPLETE");
return 0;
After doing this, my PLL doesn't get reconfigured. And after studying all three documents, i think i need help to solve this problem. PLEASE any help would be greatly appreciated. Best Regards, Pratish Karmacharya
Anyone? Any help?
