Hello Intel Community,
I am currently working on a project that involves integrating the KSZ8081RNDCA Ethernet PHY with RMII interface into an Intel Cyclone 10 FPGA. We connected the PHY to the FPGA, and now we are in the process of configuring the FPGA using IP blocks.
We are facing challenges in locating the RMII interface block within the available IP blocks. Our goal is to establish proper communication between the FPGA and the Ethernet PHY, and any guidance or support in configuring the FPGA for RMII interface would be greatly appreciated.
Here are some details about our setup:
FPGA: Intel Cyclone 10 (10AX016E3F27I2SG)
Ethernet PHY: KSZ8081RNDCA with RMII interface
If anyone in the community has experience with a similar configuration or has insights into configuring the FPGA for RMII interface, we would be grateful for your assistance. Any specific IP blocks, settings, or steps related to RMII interface configuration in the Intel FPGA environment would be helpful.
Thank you in advance for your time and support.
Hello ABHINAY1,
Regarding your inquiry about FPGA, we have a dedicated forum to address your issue. I will transfer your thread to that forum.
Irwan_Intel
