IC is suspected to be bad part.
Failure symptom: Unable to program SPI Flash Memory.
Part Number: AE1822-5776LF
MPN: 5SGSMD8K2F40I2LG
Failure unit: 1
Failure rate: 0.36%
Trouble shooting done: Swapped every possible component, and swap a known good programmed part , unable to detect.
Operating temperature: 25 Celcius
Supply Voltage: 0.9V
Dear SyafiqahNasir,
Thank you for using Intel FPGA Community Forum.
We will continue support your issue through private email as confidential info is required.
Thanks!
Stay safe and take care!
Wani
Topic Options
