6409 Discussions
Request for Confirmation "112465"
Ehab
Hello Team,
I hope this email finds you well.
Could you please confirm with us the REACH status for this PN "EP4CE15F17C8N"?
Based on the part's FMD: "https://cdrdv2.intel.com/v1/dl/getContent/699065?fileName=EP4CE15F17C8N_20210716113054_v1.xml", the part contains "2,4,6-Triamino-1,3,5-Triazine" with CAS "108-78-1".
We really appreciate your confirmation.
Thanks in advance for your support.
Ehab
Hello Team,
Just following up with you regarding the request below to see if you have any updates.
Your cooperation will be greatly appreciated."
Zawani_M_Intel
Hello Ehab,
Thank you for using Intel FPGA Community Forum.
Currently we are checking REACH status with our Quality Team. We will reply you back shortly.
Ehab
Hello Team,
Greetings,
We would like to follow up on our below request, as we have not received a reply yet. Would you please advise?
Have a great day!
Ehab
Hello Team,
I am just following up with you regarding the request below to see if you have any updates.
Ehab
Hello Team,
I hope you are doing well.
Just a quick follow-up to check on the status of my request. I'm really looking forward to it!
Zawani_M_Intel
Hello Ehab,
Please find the attachment "Intel DCL Product Content REACH Jan 2023".
I hope this will address your request.
If there is any questions, please do let me know.
Wani
Zawani_M_Intel
Ehab
Hello Team,
Thanks for the shared data, but the attached CoC doesn't contain the substance "2,4,6-Triamino-1,3,5-Triazine" with CAS "108-78-1" but based on the part's FMD "https://cdrdv2.intel.com/v1/dl/getContent/699065?fileName=EP4CE15F17C8N_20210716113054_v1.xml" the part contains it, and this substance is an SVHC substance, so the part should not be compliant with REACH SVHC. Could you please check and clarify the REACH status of the PN?
Ehab
Hello Team,
Ehab
Hello Team,
We would like to follow up on the request sent below, as we have not received a reply yet.
The attached CoC doesn't contain the substance "2,4,6-Triamino-1,3,5-Triazine" with CAS "108-78-1" but based on the part's FMD "https://cdrdv2.intel.com/v1/dl/getContent/699065?fileName=EP4CE15F17C8N_20210716113054_v1.xml" the part contains it, and this substance is an SVHC substance, so the part should not be compliant with REACH SVHC. Could you please check and clarify the REACH status of the PN?
