Hi all - I opened up my development kit today and read the docs with it. It pointed me to the link below to get the latest board firmware. However, on that webpage, it says that the "Kit Installation" (which I believe is the SW?) is meant for Quartus 10.1, and I'm running Quartus 11.0 SP1. Is this the right kit? Or??
http://www.altera.com/products/devkits/altera/kit-siv-gx.html Thanks! /jLink Copied
the kit installations are updated periodically and typically lag the Quartus releases
if you intend to use the board Windows applications and example designs, it would probably be best if you installed 10.1sp1 to go with the kit 10.1 installation. if you are building your own designs stick with 11.0sp1- Mark as New
well, that's a pain!
thanks! /j
