Hi Team,
I am currently using the development kit which features Intel Agilex® 7 FPGA I-Series Transceiver-SoC Development Kit (4x F-Tile). I am trying to flash the SD Card binaries to boot the device.
I have followed the below website to write SD card binaries in the SD Card.
GSRD for Agilex 7 I-Series Transceiver-SoC DevKit (4x F-Tile) | Documentation | RocketBoards.org
After flashing the SD Card binaries, I have got the error msg like "** Partition 1 not valid on device 0 **". I am using the win32diskImager tool as mentioned in the above website.
I have attached the logs for your reference.
Kindly help me to resolve the issue.
Jayasurya R.
Hi Jayasurya,
There is some switches setting to make sure in the booting steps.
Check the switch default positions first.
Then make sure you have perform the jic file flashing steps before you proceed to boot up from sd card. (Writting JIC image to QSPI Flash)
Aik Eu
Hi Jayasurya,
May I know any follow up from the previous comment?
Aik Eu
Hi Jayasurya,
I am closing the thread for now. Do consider open a new ticket if got further question.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey
Aik Eu
