6330 Discussions
SD card Prebuilt binaries for Stratix-10 EVK
Tirupataiah
I am having the Stratix-10 Soc H-Tile with part number 1SX280HU2F50E1VGAS. How can I get the pre-built binaries for SD card booting?
Which procedure i can follow to flash images into an SD card?
Please help me regarding this issue.
Thanks in advance.
mabdrahi
Hi Tiru,
I will come back to you with the info soon.
please stay tune.
Tirupataiah
Hi Mabdrahi,
Thanks for your response. I will be wait for your reply.
I hope it will be helpful to me.
mabdrahi
Hi Tiru,
Does the link useful for your case?
Tirupataiah
Hi Mabdrahi,
Thank you so much for your response.
I have tried this procedure but EVK is not booting through Sd card.
One more important point is I am having H-Tile Stratix-10, not L-Tile Stratix-10.
I am not getting the proper procedure to boot from the sd card for H-Tile Stratix-10 Board.
Is there any different method of procedure for H-Tile Stratix-10 EVK SD card boot?
mabdrahi
I will it at my end, give me sometime to reproduce
mabdrahi
Hi Tiru,
According to https://www.rocketboards.org/foswiki/Documentation/Stratix10SoCGSRDHTile#:~:text=from%20U%2DBoot-,Overview,customization.%20No%20prebuilt%20binaries%20are%20provided%20for%20the%20H%2DTile%20version.,-Prerequisites
The Stratix 10 SX SoC Development Kit H-Tile and Stratix 10 SX SoC Development Kit L-Tile are very similar boards, as documented at Intel Stratix 10 SX SoC Development Kit.
But, let work together to bring up the board using this page https://www.rocketboards.org/foswiki/Documentation/Stratix10SoCGSRDHTile
mabdrahi
Hi Tiru,
Do you have update from your side?
mabdrahi
Hi Tiru,
apologize to disturb you at this time.
May i iknow if you can boot if follow the link i give?
Tirupataiah
Hi Mabdrahi,
Sorry for delay. I have tried that link you mentioned for H-Tile S10 EVK.
But, I am getting the error after entering the below command.
~/intelFPGA_pro/23.2/nios2eds/nios2_command_shell.sh make generate_from_tcl
 I am attaching the error in the below Screenshot.
We are using nios2 command shell with version of 18.1 instead of 23.2.
(Virus scan in progress ...)
mabdrahi
Actually we need to use quartus 23.2 to compile. I will give my generated sdimage to you.
give me some time to build it
mabdrahi
Im attaching hardware after compile using 23.2 quartus version
mabdrahi
Hi Tiru,
I already send you sdcard image using email
Tirupataiah
Hi Mabdrani,
I did not receive any sd card image to my mail from you.
Please send it again to me.
I have using 23.2 only to generate the rbf but still i am getting errors.
I will share the error log very soon.
mabdrahi
Hi Tiru,
I hope you doing well,
May i know about the update from your side?
Tirupataiah
I did not receive your sd image. Please send it again.
I am using 23.2 nios shell to build the hardware design but still i am getting the below error.
2023.08.18.15:44:50 Info: Synchronizing System Information for mge_led_pio
2023.08.18.15:44:50 Info: Synchronizing System Information for mge_rcfg_pio
2023.08.18.15:44:50 Info: Synchronizing System Information for frz_ctrl_0
2023.08.18.15:44:50 Info: Synchronizing System Information for frz_bdg_0
2023.08.18.15:44:50 Info: Synchronizing System Information for s10_hps
2023.08.18.15:44:52 Info: Synchronizing System Information for emif_hps
2023.08.18.15:44:52 Info: Synchronizing System Information for f2sdram_m_0
2023.08.18.15:44:52 Info: Synchronizing System Information for f2sdram_m_1
2023.08.18.15:44:52 Info: Synchronizing System Information for f2sdram_m_2
2023.08.18.15:44:52 Info: Synchronizing System Information for fpga_m
2023.08.18.15:44:52 Info: Synchronizing System Information for hps_m
2023.08.18.15:44:52 Info: Synchronizing System Information for jtag_clk
2023.08.18.15:44:52 Info: Synchronizing System Information for jtag_rst_in
make[1]: *** [Makefile:675: qsys_generate_qsys] Error 1
make[1]: Leaving directory '/home/tirupataiah/Tiru/stratix10_gsrd/s10_soc_devkit_ghrd'
make: *** [Makefile:695: generate_from_tcl] Error 2
tirupataiah@LAP841U:~/Tiru/stratix10_gsrd/s10_soc_devkit_ghrd$
mabdrahi
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
mabdrahi
Hi Tiru,
I sending again using email.
please acknowledge me the status
Stay tune
mabdrahi
Hi Tiru,
I would like to have call
What is your GMT and suitable time?
Tirupataiah
Hi Mabdrahi,
Once i have received the SD card image from you, i will give you the conformation.
My GMT is GMT +5:30 hours. Based on that you can schedule the meeting i can join in that.
Thank you.
