6367 Discussions
SD card and eMMC Transceivers for 1.8V
SB_S
Do we need to have transceivers if we support  1.8V IO level on FPGA ? Doesn't have the capability to support the 1.8V ?
And also it requires the PU to 3.3V on these interface. ​Are these mandatory ?
EBERLAZARE_I_Intel
Is your question referring to SD/MMC and eMMC Card Interface Design?
If so, could you rephrase your questions again?
SB_S
​Yes , question is referred to  SD/MMC and eMMC Card Interface Design.
In the above table ,  for 1.8V SD/MMC Flash memory needs external transceiver . What does it mean ?
EBERLAZARE_I_Intel
I see, well since the HPS I/O use a fixed voltage level and cannot be changed dynamically, transceivers are required to support level-shifting and isolation for cards that can operate at 1.8 V.
The SD/MMC cards support various operating voltages, for example 1.8V and 3.0V. If you have a card which is at 1.8V and you eject it and replace it with another card, which is 3.0V, then voltage switching is required. Many SD cards have an option to signal at 1.8 or 3.0 V, however the initial power-up voltage requirement is 3.0V. To support these different voltage requirements, external transceivers are needed.
More information here on page 1721 (Flow Diagram).
Regards.
SB_S
​So for eMMC this trancievers  are not required right ? because this voltage doesn't change as SD card . So 1.8V emmc device should work .
EBERLAZARE_I_Intel
If the operating voltages are both 1.8V as mentioned, external transceiver are not required.
Regards.
SB_S
​Thanks
