6307 Discussions
SD card driver using verilog
I am writing a code to access SD card on DE2 board. i have started with it and facing few problems with unexpected latch(es).
always @(state)
begin
case (state)
st_idle: -----
st_CMD0: begin
if (i == 8'd40)
begin
i = 8'd0;
cmd_0 = 0;
SD_CMD = crc7[6]; // send MSB of crc7
nx_state = st_crc7;
end
else
begin
cmd_0 = 1;
SD_CMD = CMD0[39-i]; // make sure MSB is sent first
crc7 = crc7 << 1; //crc = crc << 1
if (crc7[7] ^ CMD0[39-i]) // moved to crc output logic
crc7 = crc7 ^ 8'h09;
i = i + 8'd1;
nx_state = st_CMD0;
if (i%8 == 0) // moved to crc output logic
crc7 = crc7 & 8'h7F;
end
end
This is the part of my code where the following warnings appear;
Warning (10240): Verilog HDL Always Construct warning at sdcard.v(91): inferring latch(es) for variable "i", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at sdcard.v(91): inferring latch(es) for variable "SD_CMD", which holds its previous value in one or more paths through the always construct
I do understand here that 'i' has its old and current value in the same clock, but how to avoid it? And have no clue about variable 'SD-CMD'. I expect you might have come across such warnings & solved it. If so then plz help me.
Thanks in advance.
Vivek.
I am unable to recieve any response from SDCard after CMD55 or ACMD41 commands. This application command is sent every 50ms as per 1GB sandisk datasheet.
Plz help if anybody know about this issue.
Vivek
