Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
SDRAM PLL phase adjustment DE2-70
I'm trying to incorporate the SDRAM into a simple nios system. Following the tutorial it says to have a PLL output a clock with a 3ns phase shift to account for delay with respect to the controller however it doesn't work and I get this error
Verifying 00800000 ( 0%)
Verify failed between address 0x800000 and 0x800697
Leaving target processor paused
Possible causes for the SREC verification failure:
1. Not enough memory in your Nios II system to contain the SREC file.
2. The locations in your SREC file do not correspond to a memory device.
3. You may need a properly configured PLL to access the SDRAM or Flash memory.
I looked at the SDRAM controller document to find the way to calculate the timing window and calculate the right phase shift
-From the SDRAM datasheet(IS42S83200B)
Toh= 2.7ns & Tdh= 1ns
-From the classic time analyzer running with a 50Mhz clock no PLL
Th_max= 1.512ns & Tco_min=5.07ns
Read Lag = tOH(SDRAM) – tH_MAX(FPGA)= 1.188ns
Read Lead= tCO_MIN(FPGA) – tDH(SDRAM)= 4.05ns
Then my phase shift comes out to 2.862ns
It still doesn't work, what might be my problem?? I've tried many combinations and tried both SDRAMs but still get the same error, help please!!
--- Quote Start ---
--- Quote End ---
The clock for the SDRAM should LEAD with respect to the FPGA clock. The phase shift should be NEGATIVE: -3ns .
Hope this helps...
Thanks, Sorry I meant "-3ns' as well, it doesn't work and i have tried different values like -2.5 and -3.5... My calculated phase shift does come out positive so i don't know if i'm calculating it wrong or what
