SOPC Building Error
Hy All ,
I am building a simple LED test pattern from "Board diagnostics" and selecting my own system (created my SOPC builder in Quartus II).
After that I go to the "system library properties" and change the setting to "program never exits" and "small C library".
when i build them , i got below error message.
Description :
In Fuction 'GetInputString' : board_diag.o
in Function 'main' : board_diag.o
undefined reference to 'getc' : board_diag.c
undefined reference to 'sscanf' : board_diag.c
Any reply will be appreciated.
Thank you ,
Yuyex.
That's because you chose "small C library" in which scanf,getc..etc.dont work.If u deselect that "small C library",you will not get that error if you have enough program memory.
I know this error in Nios that's y i told u if u have enough programming memory then and then u will be able to run.
Anyway,you can not run this code with on chip memory.And if u unchecked "small C library" then u will not be able to use those functions.
In quartus ,u got that error only because u increase your on chip memory.Try to reduce it till it wont get an error.
And yes,Think another way for nios II but that way wouldn't work.Hope you understood .
Thank you again Supal Shah:),
"Anyway,you can not run this code with on chip memory.And if u unchecked 'small C library' then u will not be able to use those functions."
From above statements, it means that i have to run the functions off-chip memory(which can be larger)?
Btw , I want to ask another newbie question about UART.I added UART function to my system and i got "rxd_to_the_uart" and "txd_from_the_uart" pins.
My question is it necessary for those pins to be assigned to any of my DE0 board?
Thank you,
Yuyex:o
Hy all ..
I have checked the largest on-board mem for DE0 = 56 M9K = 56 x 2^13
= 57,334 Byte.
I made an 20480 Bytes on-board mem for my system.
After I unchecked the "small C library", NIOS II needs me to add another 39912 Bytes (20,480+39,912=60,392Bytes which is larger then the limitation for my DE0 board on-board mem).
Is there any suggestion for this prob?
Thank you,
Yuyex:o
