6307 Discussions
SOPC System Generation Error!
I recently started working with the Altera NiosII Development kit based on Cyclon II FPGA. When I try to open the standard reference design provided using the SOPC builder and generate the reference design I recive the following error.
isa_europa.pm: calc_max_control_reg_sz(): No register size available for register cpuid
Will be glad if anyone can help me out to understand this error. I realise what the cpuid is for but dont understand how or where I can set the size of this cpuid and why I have this error when I am trying to generate a standard example design.
Kumaran
same here when upgrading a stable design from 8.1 to 9.0sp2.
ideas anyone?
apus
Hi!,
Here is the reply I got from Altera. I could solve this issue following the steps listed down.
For error message "isa_europa.pm: calc_max_control_reg_sz(): No register size available for register cpuid", it is a running environment issue. If you have multi-version installation of Quartus II, when using v9.0, please make sure the following environment variables are set as follows (for example):
QUARTUS_ROOTDIR = C:\ALTERA\90\quartus
SOPC_KIT_NIOS2 = C:\ALTERA\90\nios2eds
Please also delete environment variable SOPC_BUILDER_PATH (but you need to save the values for restoring when using versions other than v9.0).
When using Quartus II/IP/Nios II EDS before v9.0 (such as v8.1), please recover the environment variable SOPC_BUILDER_PATH and set the value of the environment variables as follows (for example):
QUARTUS_ROOTDIR = C:\ALTERA\81\quartus
SOPC_KIT_NIOS2 = C:\ALTERA\81\nios2eds
Then remove the following folders and restart Quartus II to try it again.
c:\documents and settings\<user name>\.altera.quartus
c:\documents and settings\<user name>\ipToolbench
c:\documents and settings\<user name>\.sopc_builder.
Best Regards
Look also at
http://www.altera.com/support/kdb/solutions/rd03082007_165.html?gsa_pos=1&wt.oss_r=1&wt.oss=version%20switch
And see on that page the link Altera Tool Switch zipfile.
(for some reasons the switch only didn't work for me. When i also deleted the three folders in c:\documents ad .... it worked for me on Quartus 9.1
Rgds,
Kimberley
