I want to write an Sram controller (Read Cycle followed by a Write cycle) on Cyclone III starter kit Board. I have an external Sram (IS61LPS25632A). I have the following Signals to be controlled: Sram_ce1_n (active low), Sram_we_n (I suppose low for write, and high for read), (Sram_be_n0, Sram_be_n1,Sram_be_n2,Sram_be_n2 I set them to zero because I want to access all bytes), Sram_adsc_n (I set it to zero) and the clock Sram_clk (I put the rising edge in the middle of the cycle), Sram_oe_n (I set it to low, should i toggle it ???). The timings of the data sheet of the Sram is for me not clear, I don't nee burst access, just I want to read one address radr1 and then write another adress wadr1 and then read again radr2 and write wadr2 and so on, please can somebody provide a timing diagramm or a piece of RTL code ? thanks a lot regards ChahidLink Copied
mark.i have the same problem.
Topic Options
