6266 Discussions
Setting True LVDS input and output in MAX10
ABADY1000
I am creating a new board based on MAX10 FPGA, so I started Pin Planning Project.
As read in MAX10 docs, bank 3 and 4 support True LVDS output, but when I try to set LVDS protocol to the pins in bank 3 or 4 it complains about the absence of "Output Buffer" !
Error (169175): Pin "d337_LVCLK1_P" with LVDS I/O standard needs a differential output buffer which is not available on location T8.
Error (169175): Pin "d337_LV1_P[1]" with LVDS I/O standard needs a differential output buffer which is not available on location U11.
Error (169175): Pin "d337_LV1_P[2]" with LVDS I/O standard needs a differential output buffer which is not available on location V11.
Error (169175): Pin "d337_LV1_P[3]" with LVDS I/O standard needs a differential output buffer which is not available on location V8.
Error (169175): Pin "d337_LV1_P[4]" with LVDS I/O standard needs a differential output buffer which is not available on location V7.
Error (169175): Pin "d337_LVCLK1_P(n)" with LVDS I/O standard needs a differential output buffer which is not available on location T7.
Error (169175): Pin "d337_LV1_P[1](n)" with LVDS I/O standard needs a differential output buffer which is not available on location V12.
Error (169175): Pin "d337_LV1_P[2](n)" with LVDS I/O standard needs a differential output buffer which is not available on location V10.
Error (169175): Pin "d337_LV1_P[3](n)" with LVDS I/O standard needs a differential output buffer which is not available on location U8.
Error (169175): Pin "d337_LV1_P[4](n)" with LVDS I/O standard needs a differential output buffer which is not available on location U7.
Is there something I am missing? because I am sure bank 3 and 4 should support this protocol.
Also when it comes to mini-LVDS and RSDS it shows me this message:
Error (169299): The input pin DIFF0_P[1] has a mini-LVDS I/O standard, but the selected device does not support input pin operation with a mini-LVDS I/O standard.
Isn't mini-LVDS and RSDS supported ?
Emulated protocol works for all banks as expected
AndrewG_Intel
Hello @ABADY1000
We understand that you have some inquiries regarding Intel® Max® 10 FPGA. We have a forum for those specific products and questions so we are moving it to the FPGA, SoC, And CPLD Boards And Kits Forum so it can get answered more quickly.
Andrew G.
ABADY1000
AminT_Intel
To avoid this error use the Emulated LVDS standard assignment LVDS_E_3R or LVDS_E_1R.
Thank you.
ABADY1000
Hello AminT_Intel,
I know I can use Emulated protocols, my question is about the true ones, shouldn't MAX10 support them ? Why I can't use them?
I want to lower the number of resistors on the board and reach faster signals speeds since True protocols capable of handling faster clocks and data rates.
AminT_Intel
There are requirement to do that and you have to follow the right specification (like example the right I/O standard) to be able to do that. Please refer our to our document (Intel® MAX® 10 FPGA Device Datasheet) on your design.
Thank you
ABADY1000
Hello AminT_Intel,
Mr. AminT_Intel, the device supports True LVDS as stated in (Intel® MAX® 10 FPGA Device Datasheet), so why I can't use LVDS in these bank3 and 4 pins ?!
Please if are willing to help me, give me a good answer, not a general statement.
AminT_Intel
True LVDS input buffer is supported in all I/O banks
True LVDS output buffer is only supported on bottom I/O banks.
Please refer to Intel® MAX® 10 High-Speed LVDS I/O User Guide for detailed explanation.
Thank you.
AminT_Intel
 We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
