6370 Discussions
SockIt System Console in Q-II v13.1
I'm just posting a problem that I found in trying to run the Arrow SoC Hardware Lab on the Sockit board in the hope of helping others avoid it.
In Module 6: System Console, the test_one.tcl script works fine when run under Q-II v13.0, but fails under v13.1.
I've traced this down to the address format in the tcl scripts. For example in test_one.tcl you may find a line:
master_write_8 $jtag_master 0x1_0040 $val
v13.1 of Q-II doesn't like the underscore in the address, so 0x1_0040 needs to be changed to 0x10040.
All of the underscores in the addresses in the scripts appear to need to be removed.
I hope this helps others.
Cheers
AL
--- Quote Start ---
Cheers
AL
--- Quote End ---
Thank you, I was struggling to run this example and I was stuck at the same problem. This kind of changing without warning is a bit annoying...
