Hello -
I have one of the Stratix 10 GX development kits, the L-tile version.
The card is installed in a Dell Precision 5820 chassis, in slot 4, a x16 Gen3 slot.
I'm looking for a known-good PCIe design that supports x16 Gen3 mode.
The card is in its original configuration. I'm able to program designs into the FPGA via the USB Blaster-II JTAG connection. Since I am running Linux, after programming the design into the FPGA, I do a 'sudo reboot -h now' to effect a warm-boot and a re-enumeration of the PCI bus.
Yet after doing this, regardless of the design I have loaded, I don't see the card in the output of lspci and it's card slot, Slot 4 on the Dell system, still shows as 'Available' in the output of 'sudo dmidecode -t 9'.
I would expect the board test package bts_pcie.sof would work for this, yet the card does not seem to enumerate even with this design loaded.
John Sambrook
Common Sense Systems, Inc.
Hi John,
For Stratix 10 GX, if you are looking at tested design, you may refer to link below for golden_top design example.
The .sof file is included for test purposes.
- https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/stratix/10-gx.html
- If you are looking for other Stratix 10 design example, you may refer to our FPGA Design Store - Intel
Let me know if this is helpful.
Wincent_Intel
Hello Wincent_Intel,
Thanks for the quick and helpful reply.
When I have access to the board later this morning, what PCIe Vendor ID and Device ID will the board respond with when the golden_top.sof design is properly programmed and I run sudo lspci from a shell prompt on the system?
John Sambrook
Hi Wincent_Intel,
I have the production version of the development kit downloaded.
The examples/golden_top folder is an empty design. The readme starts off with
"The top file here is only for pin assignment reference. The project is just an empty
one without any design example in it."
I am looking for an already-compiled design that I can load into my development
board and to confirm that the board will enumerate in the Dell 5820 chassis
in which the board is located.
To cut to the chase, I'm looking for an already compiled design (.sof file) that I can
program into my board, while it is in-chassis, that will enumerate when the Linux
system is warm-booted.
Is the factory default design one such design? Should I be able to plug in my
stock development board, with no changes to board configuration (DIP switch
settings or anything else) and expect it to enumerate when it's in a working
x16 Gen3 slot?
John Sambrook
Hi John,
There is no already compiled design (.sof file) that is available.
You need to generate it based on the PCIe design example either AVST, AVMM or MCDMA.
Detail step to generate the .sof file, you may refer to the Stratix 10 AVST user guide, under Section 1.5 , page 9/12
Let me know if the step is not clear, if you are unable to perform it.
Wincent_Intel
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
John Sambrook
Hi John,
Can you provide me your device OPN number ?
I will generate a .sof file on behave and then sent it back to you.
Wincent_Intel
Hello Wincent,
Thank you kindly for your help with this.
The Ordering Part Number is 1SG280LU2F50E2VG.
Will you test the design in the same kind of development kit as I have, so
that what you send me is something I know has been proven to work in
other development kits of the same kind?
My development kit is a DK-DEV-1SGX-L-A.
Hi John,
I will help to generate the .sof file and .stp file for you.
But I do not have the specific hardware on my place.
Might need you to help test it once done, but I will ensure that it is workable.
Forget to ask which version of Quartus that you are using currently.
Hi Wincent,
I am using Quartus Prime Pro 22.3.
Thank you for your help.
John Sambrook
Hi John,
the .sof file and .stp file is generated.
But I cannot sent it by here due to forum limitation, I try your register email, it fail as well due to file too large.
- Do you have any cloud server that I can upload to you ?
- or can you please file an Intel Premium Support (IPS case) for that ?
Hoping to hear back from you
Wincent_Intel
Hi John,
Is there any update from my previous message?
Wincent_Intel
Is there any method that I can provide the .sof file to you as the file is unable to upload in this forum thread.
- The .sof file is quite easy to generate by generating an example design, example PCIe Avalon ST.
- Run the synthesis/full compilation.
- Open the signal Tap, and capture the signal as below to check the LTSSM linkup/enumeration/
Hoping to hear back from you.
Wincent_Intel
Hi Wincent,
Thanks for your reply. I can send you credentials to store the file on my Dropbox.
Is there are direct email address I can use that will reach you?
I don't to post the credentials in an open forum here.
You can also try my email address at Protonmail if you want: john.sambrook@protonmail.com.
John Sambrook
Hi John,
Did you able to run the .sof and .stp file ?
Wincent_Intel
Hi Wincent -
I have not yet tried it out. I just found this video today and I wanted to ask you about it:
Did you use this in your design?
Also, with the Board Test System it's possible to give it a .sof file or a .pof file, is that right?
And if so, does the BTS work properly when doing programming in the manner specified
in the Intel YouTube video linked above?
Thanks in advance for your help.
Best,
John
Hi John,
The video was from "configuration IP", it is supported by the other specialist.
If you wish to know more about it , I do suggest you to open a new ticket for that.
I believe the specialist will provide a better opinion than me (specific on that part).
Wincent_Intel
Wincent_Intel
Hi Wincent -
Thanks for your help on this.
After some searching I and one of my colleagues found the following resources. I think they are critical for anyone who wants to program boards like the Stratix 10 GX L-tile board that I have.
Posting them here so that perhaps others will benefit from them:
How to perform Avalon®-ST Configuration by using Parallel Flash loader II Intel® FPGA IP Core
Parallel Flash Loader II: How to convert .sof file to .pof file
Please do go ahead and close this call. Thank you for your help.
John Sambrook
Hi John
Glad that you found the answer, thanks for share with me in here.
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
