I am using the Stratix 10 MX (8 Gb) Development Board (Device: 1SM21BHU2F53E2VG) to test out the Low Latency 100G Ethernet Intel Stratix 10 FPGA IP Design Example on Quartus v19.1.
I have reached step 1.8 in the design example user guide successfully, but I am getting a very weird results to no results. I have no idea why the IP core is not working as intended. I have attached the .qsf file, the System Console output, and the Ethernet link screenshots.
IP Core User Guide: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_s10_ll_100gbe.pdf
Design Example User Guide: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-ll-100gbe.pdf
Thank you.
By referring to the qsf file, it looks like you did not do the pin assignment correctly, you are testing the QSFP /100G ethernet, but you assign the clock and TX/RX Pin to PCIe. Please refer to the user guide or the schematic below for more detail:
Regards -SK
Regards -SK
Hi Sengkok,
Thanks for pointing the incorrect pin assignment out!
Unfortunately, I am having the same poor results where nothing appears to be working. I have attached the updated qsf file.
Lars
Hi Lars,
You may check turn on the Internal serial loopback for this design example. If this is not working, then I suspect there might be something wrong with your clock source or pin assignment.
Regards -SK
Hi SengKok,
You were correct, it was a pin assignment problem. When I moved the clock pin from AG43 or CHT to AJ43 or CHB it started working.
Thanks for your help!
Lars
Hi Lars,
This is glad to see the problem resolved. If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Regards -SK
