I am trying to compile an example design for the Stratix 10 SOC Development Kit.
Under Development Kit Documentation , I downloaded and installed
L-Tile Production (18.0.1 or higher)
Tried the following example from the examples folder with Quartus Prime Pro Version 18.0.1 Build 261
example folder : qts_fmca_Q18.0.1_B261
Opened qts_fmca.qsf file
When compiled , it failed
Noticed the following entries under project -> add/remove file panel:
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_clk_50.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_tx_fifo_converter_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_freq_counter_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_tx_rx_clkout2_converter_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_mm_bridge_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_rx_fifo_converter_0.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_rx_fifo.ip
../../../../../../../../../../p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_checker_0.ip
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/xcvr_test_system.qsys
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/cmos_test_system.qsys
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx_2.qsys
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_cmos_system.qsys
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx.qsys
../../../../../../../../../nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gxt.qsys
Removed , these entries and added them back , selecting them from the qts_fmca folder. Now when I compile, I am getting the following errors:
Error (13225): Can't open VHDL or Verilog HDL file "ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_e7kc4bi.sv"
Error (13223): Verilog HDL or VHDL error: cannot open verilog file 'ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_e7kc4bi.sv'
Error (13225): Can't open VHDL or Verilog HDL file "ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra.sv"
Error (13223): Verilog HDL or VHDL error: cannot open verilog file 'ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra.sv'
Error (13225): Can't open VHDL or Verilog HDL file "ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra.sv"
Error (13223): Verilog HDL or VHDL error: cannot open verilog file 'ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent/altera_xcvr_atx_pll_s10_htile_180/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra.sv'
Error (16045): Instance "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_gx2_1c|q_sys_xcvr_atx_pll_s10_htile_0" instantiates undefined entity "fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_e7kc4bi" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_gx2_1c|q_sys_xcvr_atx_pll_s10_htile_0" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1c_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_gx2_1c"
Error (16045): Instance "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent|q_sys_xcvr_atx_pll_s10_htile_0" instantiates undefined entity "fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent|q_sys_xcvr_atx_pll_s10_htile_0" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1d_above_adjacent" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/fmc_xcvr_system/synth/fmc_xcvr_system.v Line: 435
Error (16045): Instance "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent|q_sys_xcvr_atx_pll_s10_htile_0" instantiates undefined entity "fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent_altera_xcvr_atx_pll_s10_htile_180_44d53ra" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent|q_sys_xcvr_atx_pll_s10_htile_0" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/ip/fmc_xcvr_system/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent/synth/fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent.v Line: 229
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst|fmc_xcvr_system_xcvr_atx_pll_s10_htile_gxt_1f_above_adjacent" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/fmc_xcvr_system/synth/fmc_xcvr_system.v Line: 451
Error (16185): Can't elaborate user hierarchy "fmc_xcvr_system_inst" File: C:/Intel_designs/qts_fmca_Q18.0.1_B261/qts_fmca.v Line: 186
Error (16186): Can't elaborate top-level user hierarchy
Error: Flow failed:
Error: Quartus Prime Synthesis was unsuccessful. 18 errors, 51 warnings
I was hoping to be able to compile as downloaded without any edits. I am using th same Quartus edition, this example was supposedly built under. Appreciate any help.
Have you you tried opening the original and entire project file, ".qpf", then try recompiling it after opening the .qpf file.
Yes. The following are the errors that I get with Quartus Prime Pro 18.0.1 Build 261
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_tx_fifo_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_freq_counter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_tx_rx_clkout2_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_mm_bridge_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_rx_fifo_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_rx_fifo.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_checker_0.ip.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/xcvr_test_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/cmos_test_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx_2.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_cmos_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gxt.qsys.
Error: Quartus Prime IP Generation Tool was unsuccessful. 15 errors, 0 warnings
Error: Peak virtual memory: 4717 megabytes
Error: Processing ended: Tue Jul 13 15:18:36 2021
Error: Elapsed time: 00:00:29
Error: Total CPU time (on all processors): 00:00:35
Error(293001): Quartus Prime Full Compilation was unsuccessful. 17 errors, 0 warnings
Do you have a valid Quartus Pro license? Did you try to compile the GHRD instead if that would compiled succesfully.
