5931 Discussions
Stratix III transcend DDR2 DIMM timing
Anybody there having Stratix III Dev Kit with transcend memory dimm rather than the micron one....please help as my DDR2 RAM is not working.
Thank you
I am having the same problem since ive upgraded to Quartus v9.1. But ive just found the true datasheet of the memory board by the chip number: HY5P81G831C FP-S5. The datasheet is in:
http://www.hynix.com/inc/pdfdownload.jsp?path=/datasheet/pdf/dram/hy5ps1g4(8.16)31c(l)fp(rev0.6).pdf (http://www.hynix.com/inc/pdfdownload.jsp?path=/datasheet/pdf/dram/hy5ps1g4%288.16%2931c%28l%29fp%28rev0.6%29.pdf
Check if your board have the same chip. Im making the config file and ill test it tomorrow. If it works i will post it here.
