Are any existing modules/daughter cards for 10/40/100G Ethernet are compatible with for this kit ?
--- Quote Start --- Are any existing modules/daughter cards for 10/40/100G Ethernet are compatible with for this kit ? --- Quote End --- Vadatech make FMC boards, and the support is excellent. You should be able to use the QFSP+ breakout board. FMC108 has Vitesse PHYs on it ... http://www.vadatech.com/product.php?product=296&catid_prev=0&catid_now=219 I think the FMC107 is just a straight connection to the FMC connector http://www.vadatech.com/product.php?product=294&catid_now=0&catid_prev=0 HiTech Global also have FMC boards. You might want to look at their FMC-to-SMA connector if you just want direct access to the transceivers. Before purchasing these boards, create a spreadsheet of the FMC connector pinout and make sure the Altera kit has included all the pins needed by the FMC card. Cheers, Dave
Thanks a lot for http://www.vadatech.com, I haven't found their boards online easily.
I originally thought than HiTech Global Vita57.1 daughter cards was only compatible with their Virtex7 boards, but looks like their are more universal.
