6309 Discussions
Stratix V GX SI Dev Kit - Sometimes no link in Transceiver Toolkit
i am using the mentioned board and successfully tested an external transceiver loop with the examples (10312 mbps). I also changed the phy in qsys to fractions of 10312 mbps whichs works as long as the reference clock remains constant.
Now I changed to 6000 mbps with 300 MHz and i get no link, also 12500 mbps with 500 MHz refclk.
In another case I configured the low latency PHY with 8000mbps and 500 MHz and it works without problems.
I changed the refclk to 500 MHz in Qsys/clocks, Qsys/phy and in the sdc-file and of cause i changed the clock on the board.
Does anyone has an idea why some datarates doesn't work, respectivly what I forgot?
Thanks, Micha
It sound weird, the higher rate works fine while lower rate seems problematic. You mentoned it does not work in external loopbavk, how about internal loopback?
Question: thd first attempt is work on custom phy or native phy?
can try the non-working rate on low latency phy as seem low latency phy is alqays working?
--- Quote Start ---
--- Quote End ---
i will take a look.
--- Quote Start ---
--- Quote End ---
All rates are made on low latency phy. So, I can't follow you exactly, can you give me some more explainations :)?
Ok, if all on low latency phy, then it is fine. I though u try on different phy. I am trying to isolate the common failure symptom from your experiments
Maybe u can try the 6gbps using Native Phy, to isolate whether is phy dependent.
