5930 Discussions
Stratix V GX dev kit does not work
After i flashed my device. No LED on the board is turned on and the fan runs will full speed. Is the board damaged?
thanx
You can check the “Restoring the Flash Device to the Factory Settings” & then try again for “A. Programming the Flash Memory Device”.
Have you faced any issue /Error while programming the Flash memory?
--- Quote Start ---
--- Quote End ---
Refer the “6. Board Test System”,
https://www.altera.com/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Best Regards
Vikas Jathar
--- Quote End ---
The MAX ERROR LED in on after flashing the factory Max V.POF file.
--- Quote Start ---
--- Quote End ---
That means FPGA configuration from Flash has failed so try to restore factory setting again refer previous post.
Best Regards
Vikas Jathar
