After i flashed my device. No LED on the board is turned on and the fan runs will full speed. Is the board damaged? thanxLink Copied
You can check the “Restoring the Flash Device to the Factory Settings” & then try again for “A. Programming the Flash Memory Device”. Have you faced any issue /Error while programming the Flash memory? --- Quote Start --- Is the board damaged? --- Quote End --- Refer the “6. Board Test System”, https://www.altera.com/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)- Mark as New
--- Quote Start --- Hi, You can check the “Restoring the Flash Device to the Factory Settings” & then try again for “A. Programming the Flash Memory Device”. Have you faced any issue /Error while programming the Flash memory? Refer the “6. Board Test System”, https://www.altera.com/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation) --- Quote End --- The MAX ERROR LED in on after flashing the factory Max V.POF file. Regards,
--- Quote Start --- The MAX ERROR LED in on after flashing the factory Max V.POF file. --- Quote End --- That means FPGA configuration from Flash has failed so try to restore factory setting again refer previous post. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
