Stratix development board
There are boards without transceivers with a budget of 1000€?
Look on the Terasic site. They list the price of all the Altera boards.
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=13&list=simple
I do not see any Stratix boards for under USD$1100, but there are some Arria and Cyclone boards.
What Stratix feature did you need?
Cheers,
Dave
Hello Dave,
I am searching an FPGA with a fast logic for HPC, also 1100$ is ok but lower cost I see is Altera DE3 that cost 1800$ + VAT.
Maybe I can go with an Arria..
Thank you
--- Quote Start ---
--- Quote End ---
Any FPGA board is good for HPC.
--- Quote Start ---
--- Quote End ---
You're not doing your shopping correctly.
First determine what sort of HPC you want to do, eg., do you need OpenCL support, do you need PCIe support, do you need Ethernet support, etc.
Then look at boards with those features, then create a design for one of those boards, and see if you can place-and-route your HPC application.
Then and-only-then do you decide to buy a board.
Otherwise you're just wasting your time. What happens when the board arrives and it does not do what you want? Do your research *before* you buy a board.
Cheers,
Dave
Thank you Dave,
Sorry for my shortness before, I already have a design tested on Cyclone V and I want to improve fmax upgrading to Stratix. From Quartus Subscription trial I have seen improvements on these high-end devices.
I don't need PCIe, Ethernet, Transceivers, etc.. only uart to usb to receive and send a few bytes..
I don't need to buy the dev-board with stratix but only to compare pc-based solution with fpga-based solution at same price (1k$) with TimeQuest and see what fmax I can get for now with device of 1k dev-board :)
--- Quote Start ---
--- Quote End ---
Ok.
--- Quote Start ---
--- Quote End ---
There aren't really any boards with Stratix devices that are that simple ... They're a very expensive FPGA, so most development kits include lots of support logic, hence they all cost > $1k.
--- Quote Start ---
--- Quote End ---
Just do the comparison using Quartus then, don't actually buy the development kit :)
Cheers,
Dave
Yeah comparison with a 1k$ board :) more cheap then real board
This is the lowest-cost high-end Arria V GZ board I have found ...
http://www.ti.com/tool/tsw14j56evm
$800.
Cheers,
Dave
If you are a student or teacher at school, Terasic will provide you much cheaper price (academic price) which they couldn't publish on webpage. It might be possible to get a large Stratix 4/5 board running OpenCL for HPC application. Simply check with them.
