6418 Discussions
Stratix10 E-tile how to use the nine reference clock
DXu2
Partner
Stratix10 E-tile how to use the nine reference clock?What should I pay attention to?
Deshi_Intel
HI,
Your question is too generic. My best answer for you is to check out E-tile user guide doc chapter 4 that explained on E-tile refclk pins
Basically NativePHY IP support refclk pin switching up till 5 pins in one NativePHY design.
  • Meaning you can connect different refclk pins to different clock frequency and switch between different refclk pins in actual application test later to support different data rate
dlim
Deshi_Intel
I have not hear back from you.
I hope I have clarified your doubt.
For now, I am setting this case to closure.
dlim
