5777 Discussions
Stratix10 MX dev kit on ubuntu 18.04 - quartus programmer window not detecting FPGA
Gurpreet
below listed the setup and issue
  1. Server setup with ubuntu 18.04
  2. Installed quartus prime pro 21.2 on the server (added USB driver as specified on web)
  3. Plugged stratix-10 MX card on PCI slot, added power cable (J11) and connected USB cable (for bitfile download)
  4. ISSUE: Not able to find the hardware (FPGA) on the programmer window of quartus
any suggestions, what am i doing wrong here?
JohnT_Intel
May I know if you are able to check SW2 switch (https://www.intel.com/content/www/us/en/programmable/documentation/cbc1517362051825.html Figure 3) to see if include the S10? If yes, what do you observed when you performed auto detect in Quartus Programmer?
Gurpreet
HI, SW2 switch is in off, off, on, off (1,2,3,4) position. SW2_S10 is in off state.
Autodetect is not helping in detecting the board, programmer window just waits and come back to previous state (no message) SW2_SW10_Stratix.JPG
JohnT_Intel
Could you try changing your SW2 to OFF, ON, ON, OFF and OFF, OFF, ON, ON? Then provide me the Quartus Programmer message for both the SW2 switch setting.
Gurpreet
Device is visible after setting SW2 to OFF, ON, ON, OFF position. thanks.
JohnT_Intel
Glad to hear that the issue is resolved after changing the SW2 switch.
