5930 Discussions
TSE MAC, RGMII, Marvell 88E1111 PHY
I am using a Cyclone IV GX dev kit. I have built a qsys system with TSE MAC core. The MDIO connection with the PHY works well. I have enabled the PHY delay options. But I cannot send and receive packet via the on board Marvell 88E1111 Ethernet transceiver.
Thank you. It works now.
Some bits of transmitted frame is changed when it is received in PC. Why this is happening?
Can you be more specific? The MAC can overwrite the source MAC address field, it can append a CRC, in will insert padding if the packet is too short, etc. What are you seeing?
I am sending the following frame from TSE :
0x00, 0x00, // for 32-bit alignment
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, // destination address
0x00, 0x07, 0xED, 0x1B, 0x07, 0xE0, // source address
0x00, 0x2E, // length or type of the payload data
0x34,0x34,0x34,0x34,0x34,0x34,0x34,0x34,0x34,0x34, //payload
the received frame is
ffffffffffffff0f0007edbe7107e000e07207e034e3433434 34434334343443433434344343343434434334343443433434 34434334343443433434344343343434434334343443433434 34434334345645.
Can you tell me why received data is changed?
shuhana -
Your frame is getting corrupted somehow. The first step would be to isolate where the corruption is occurring (in the FPGA or somewhere downstream). I recommend using SignalTap to see what actually goes into and out of the MAC.
Do you have a NIOS in the design? Are you using a DMA?
And how are you capturing the received frame? Are you using wireshark or something equivalent? At this point you just have to follow the packet from where it originates in the FPGA all the way through to where you receive it and find out where things go wrong.
I tried to use signaltap to debug the system. But I found transmission data always zero.
I hava a NIOS in the design & i am using SGDMA. I am using wireshark to see transmitted packets.
Can you tell me which mac and phy registers i have to initialize so that it works properly?
