Hello! I'm try a TSE IP Application (10/100/1000 MII/GMII with Fifo settings)
I want enable MAC FILTER on receive frames:
I set TSE_MAC control register as:
TSE_CTRL_FRM_ENA = 1 (control of rx frames enabled)
TSE_PROMIS_EN = 0 (promiscous mode off)
I set primary Macs with LSB=0 or LSB =1 to try (Unicast/multicast)
I try to set all 4 secondary macs as the primary (BUT WHEN I READBACK VALUE TSE GIVE ME 0, instead primary mac is correctly read/write)
Well (or Damn'd) , mac filter doesnt' work and TSE on rx user side give me all frames that arrives from the LAN..
The hard point is why I cannot write secondary Macs?
Have you meet similar issue?
(Quartus 18.1, arria10 device, IP TSE)
Hi Sir,
Tested the TSE MAC filter in simulation. It work well.
Did you follow the link below, section 5.3.1 for the recommended initialization sequences?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
Regards -SK
Topic Options
