5542 Discussions
TSE with the dual SGDMA modules...
Hi All,
I guess I am uncertain how the TX/RX dma's work on the TSE - specifically I am looking to be able to read a few bytes out of a packet, use these bytes to select a memory mapped data structure (one of say 16 port buffers), calculate the start dma position from the buffer's rd/wr pointers, then load the descriptor on the rx dma and pull the trigger.... is this possible while still using the standard BSP generated code?
I am thinking I am missing something - if the tse performs all of this on the fly without allowing the kind of mid-stream sorting of data that I am looking to do, then I will need to change my approach.
Meaning if the tse allocates ram, transfers the data and gives back pointers into memory, then I could use a linked list approach to handling the data... sorting the list into queues and maintaining the lists for egress port transfers (via another SGDMA)...
You would have to modify the TSE driver to do that, but it should be possible.
You could prepare a first descriptor for the SGDMA asking to load only the first bytes you require, and then when you decide what to do with the data, create a second descriptor to load the remaining bytes in the packet. You can have a look at the sgdma datasheet (http://www.altera.com/literature/hb/nios2/qts_qii55003.pdf) to see how it works.
The way that I am transferring data is via a udp socket - I get 2 back-to-back transfers, the first containing a command - (ex a burst data command has a queue number and length). The second transfer is raw data destened to dram. I am using the command transfer decode to build rx descriptors for the sgdma_rx block. Should the transfer simply kick off on the next receipt of data if this was done correctly? I've attached the code if anyone is interested....
Thanks (again)
crayner
Yes, theoretically it should work.
