5550 Discussions
TX_OUTCLOCK_PHASE_SHIFT in soft LVDS
KNaka47
I set "Desired transmitter outclock phase shift" of MAX10 soft LVDS setting as below,
// Retrieval info: <generic name = "FUNCTIONAL_MODE" value = "TX" />
// Retrieval info: <generic name = "USE_EXTERNAL_PLL_UI" value = "false" />
// Retrieval info: <generic name = "TX_OUTCLOCK_PHASE_SHIFT_UI" value = "49.29" />
 (The above are in the generated file)
.tx_outclock
.tx_out
No change was seen in the phase relationship.
Do I need to set anything else?
thankyou​
YuanLi_S_Intel
Hi Kimi,
May i know have you tried to use the LVDS generated? is it working fine?
Thank You.
