Hi
As a total newbie to Altera NIO II development I am having problems compiling/fitting a project supplied with a development kit. The kit is the Terasic Cyclone III Embedded development kit. The project is: cycloneiii_3c25_niosii_standard That I downloaded from the Terasic website as part of the NIOS II embedded evaluation kit, Cyclone III edition V8.0.1. The version of quartus I am using is 11.0. After trying to compile the project I am getting the following errors (first of all Quartus could not find ddr_sdram_phy_ddr_pins.tcl, I then attempted to make a version from a version of the file on the web and hey presto it created itself)….. --- Quote Start --- Error: ERROR: Open project does not exist. Open an existing project or create a new project. while executing "export_assignments" invoked from within "if {$make_assignments} { set_global_assignment -name FAMILY "Cyclone III" set_global_assignment -name DEVICE EP3C25F324C8 set_global_assignment -na..." (file "./ddr_sdram_phy_ddr_pins.tcl" line 42) invoked from within "source $fn" (file "ddr_sdram_phy_ddr_timing.sdc" line 61) --- Quote End --- and then at the end of the process… --- Quote Start --- Error: Can't fit design in device Warning: Following 16 pins must use external clamping diodes. Info: Pin top_flash_ssram_d[0] uses I/O standard 2.5 V at H3 Info: Pin top_flash_ssram_d[1] uses I/O standard 2.5 V at D1 Info: Pin top_flash_ssram_d[2] uses I/O standard 2.5 V at A8 Info: Pin top_flash_ssram_d[3] uses I/O standard 2.5 V at B8 Info: Pin top_flash_ssram_d[4] uses I/O standard 2.5 V at B7 Info: Pin top_flash_ssram_d[5] uses I/O standard 2.5 V at C5 Info: Pin top_flash_ssram_d[6] uses I/O standard 2.5 V at E8 Info: Pin top_flash_ssram_d[7] uses I/O standard 2.5 V at A4 Info: Pin top_flash_ssram_d[8] uses I/O standard 2.5 V at B4 Info: Pin top_flash_ssram_d[9] uses I/O standard 2.5 V at E7 Info: Pin top_flash_ssram_d[10] uses I/O standard 2.5 V at A3 Info: Pin top_flash_ssram_d[11] uses I/O standard 2.5 V at B3 Info: Pin top_flash_ssram_d[12] uses I/O standard 2.5 V at D5 Info: Pin top_flash_ssram_d[13] uses I/O standard 2.5 V at B5 Info: Pin top_flash_ssram_d[14] uses I/O standard 2.5 V at A5 Info: Pin top_flash_ssram_d[15] uses I/O standard 2.5 V at B6 Warning: Following 2 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results Info: Pin top_mem_clk has a permanently enabled output enable Info: Pin top_mem_clk_n has a permanently enabled output enable Error: Quartus II Fitter was unsuccessful. 2 errors, 593 warnings Error: Peak virtual memory: 314 megabytes Error: Processing ended: Tue Jul 05 10:00:26 2011 Error: Elapsed time: 00:00:43 Error: Total CPU time (on all processors): 00:00:40 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 726 warnings --- Quote End --- How can I find out what is not fitting? As the flow summary says….. --- Quote Start --- Total combinational functions 7,169 / 24,624 ( 29 % ) Flow Status Flow Failed - Tue Jul 05 10:00:25 2011 Dedicated logic registers 5,442 / 24,624 ( 22 % ) Quartus II Version 11.0 Build 157 04/27/2011 SJ Web Edition Revision Name cycloneIII_3c25_niosII_standard Top-level Entity Name cycloneIII_3c25_niosII_standard Family Cyclone III Device EP3C25F324C8 Timing Models Final Total logic elements 9,229 / 24,624 ( 37 % ) Total registers 5530 Total pins 118 / 216 ( 55 % ) Total virtual pins 1 Total memory bits 72,456 / 608,256 ( 12 % ) Embedded Multiplier 9-bit elements 4 / 132 ( 3 % ) Total PLLs 2 / 4 ( 50 % ) --- Quote End ---Link Copied
