edit: I might sound childish, but I really need to find a solution very soon (within a day hopefully)
I am trying to display different answers of a CSP onto the LCD Display, but only the first answer shows up? Does anyone know how to continuously refresh and display text on the LCD WITHOUT Nios II (plain old Verilog)? Thank youLink Copied
Did you figure out how to do this? I found your (very old) post through search but with no result/solution.
I know there are some designs available on OpenCores.
--- Quote Start --- Did you figure out how to do this? I found your (very old) post through search but with no result/solution. --- Quote End --- Hey, I was looking through my spam mail and found your question to my 4 year old post. I ended up using a solution from: http://www.johnloomis.org/digitallab/. Essentially, I took one of the LCD examples and modified the connections to output the desired text. Hope this helps you!
