Terasic DE2-115 flash elf
Am using Quartus/Eclipse with DE2-115. Can someone provide some guidance on how to compile NIOS based application developed under eclipse so it can be falshed as opposed to loading through the debugger each execution.
Thnx
ME
Hello
In the NIOS IDE you will find <NIOS II -> Flash Programmer> (depending on the version). There is also a nios 2 stand alone flash programmer available.
brunjak
