6369 Discussions
The fpgainfo phy showing a port is flapping state
Ravishankar
fpgainfo phy | grep -e "^PCIe" -e "^Port"
PCIe s:b:d.f         : 0000:8a:00.0
Ports Num           : 01
Port0 25G           : Up
Port1 25G           : Down <<<<<<<<<<<<<<<<<<<<<<<<<<<<
PCIe s:b:d.f         : 0000:1c:00.0
Ports Num           : 01
Port0 25G           : Up
Port1 25G           : Up
Ports Num           : 01
Port0 25G           : Up
Port1 25G           : Up
Ports Num           : 01
Port0 25G           : Up
Port1 25G           : Up
SengKok_L_Intel
In order to better assist you, would you please let us know which PAC card that you are using? Is this N3000 or D5005?
Besides, what type of server you are using for this PAC card? How many PAC cards in that server?
Regards -SK
Ravishankar
Thi is N3000 PAC Card. We are using Quanta server.
There are two PAC card in this server.
Ravishankar
Please find the detailed FPGAINFO output-
FPGA port mapping
[root@<Compute_Name> ~]# fpgainfo phy | grep -e "^PCIe" -e "^Port"
Ports Num           : 01
Port0 25G           : Up  << vc_sriov1
Port1 25G           : Up  << vc_sriov3
Ports Num           : 01
Port0 25G           : Up  << vc_sriov0
Port1 25G           : Down << vc_sriov2
Check FPGA ports status with "fpgainfo phy" command.
Board Management Controller, MAX10 NIOS FW version D.1.0.12
Board Management Controller, MAX10 Build version D.1.0.12
//****** PHY ******//
Object Id           : 0xEE00001
Device Id           : 0x0b30
Numa Node           : 1
Ports Num           : 01
Bitstream Id         : 0x2230120056D577
Bitstream Version       : 0.2.2
Pr Interface Id        : cf9b1c50-37c9-45e9-8030-f921b17d2b3a
//****** PHY GROUP 0 ******//
Direction           : Line side
Speed             : 25 Gbps
Number of PHYs        : 2
//****** PHY GROUP 1 ******//
Direction           : Fortville side
Speed             : 40 Gbps
Number of PHYs        : 2
//****** PKVL ******//
Port0 25G           : Up
Port1 25G           : Down
Parkvale A Version      : 101c.1064
Parkvale B Version      : 101c.1064
Object Id           : 0xEE00000
Device Id           : 0x0b30
Numa Node           : 0
Ports Num           : 01
Speed             : 25 Gbps
Number of PHYs        : 2
Speed             : 40 Gbps
Number of PHYs        : 2
Port0 25G           : Up
Port1 25G           : Up
JonWay_C_Intel
Hi @Ravishankar​ I have sent you a private message.
JonWay_C_Intel
Hi @Ravishankar​
Does this happen to SRIOV use case only?
Could you explain the steps you took to replicate the issue?
Ravishankar
Yes this happends to only SRIOV port on the FPGA card. This is seen randomly in the Server having this FPGA card.
What are other logs that we can see to get more details of this issue?
JonWay_C_Intel
Hi @Ravishankar​
Sorry for the delayed response. May I know if this issue has been resolved?
If not, would you send me the steps to reproduce the issue.
