we are using the 10M50DAF256 in the ISP clamp mode.
For Programming this device in the Clamp mode it is taking too long time Approximately 15Min. is there any solution to program it in the lesser time.
Krishna.
Hi KBVR,
If I not mistaken the issue is caused by Quartus Prime update version.
We will update the new KDB for this issue in near future. And this bug is scheduled to be fixed in a future release of the Intel Quartus Prime software.
In the meantime, please refer to the attachment picture for workaround:
I hope this will help.
Thanks.😉
Thanks for Quick response.
As per max10 Configuration guide In system programming time for 10M50 is 52.9 Sec.
but in my board it is taking too long time i.e 14min. please see the below info it is started at 13:21 ended at 13:35. is it hardware issue or tool issue?
and observed it is taking more time at performing verification process ( 209021)
Info (209060): Started Programmer operation at Mon Sep 30 13:21:15 2019
Info (209017): Device 1 contains JTAG ID code 0x031050DD
Info (209044): Erasing MAX 10 configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Sep 30 13:35:44 2019
Thanks & Regards
Krishna
Hi Krishna,
May I know which Quartus version you are using?
Can your try it with Standard version?
Hi Krishna,
Did you Tick or Untick the "Enable real-time ISP to allow background programming when available" checkbox in the Quartus Programmer GUI before generating the JAM?
Can you try the recommended workaround (Table above) if there any improvement in timing?
Hi KBVR,
I afraid you are perform a lot of task to MAX 10 (program sector by sector and Verify it afterward), and this will take some time to program.
Maybe you can try to remove Verifying after program, this might help for your programming time.
If possible, may I have a look to your .jam file? I want to know the details your task to MAX 10.
(you can send it to my message.)
Hi KBVR,
May I know the status of this issue?
if you have any solution, you may share it to our community here.
Hi WolfGang,
We rebuilt the PCB to resolve the Programming issue, now the unit will be programmed in normal mode. we are not using the ISP mode now.
Thanks & Regards
Krishna Prasad BVR
