Hello
I has create a symbol with the toplevel from the 5 megapixel demo project TRDB_D5M_CD_v1.0 for DE2 Board. But when I insert the symbol in a block diagram and sets the Input/Output, after the synthese I have timing violation and the VGA-Monitor d'ont display a perfect image. The same problem I have with the video demo on the Terasic CD DE2_TV. In the attachment you find the two demo project, could you try on your system? Maybe your found the problem.... For any tips I thanks....Link Copied
I am having similar problems, the design compiles but fails several timing analysis tests. Has anyone solved these problems?
