6194 Discussions
Toggling HSMC GPIO as IO pins
KDS_Manikanta
Can I toggle HSMC GPIO as IO Pin in altera max 10 development board?
YuanLi_S_Intel
Yes you can. You may need to check the schematic to identify which MAX 10 FPGA pin is connecting to HSMC GPIO IO pin, then toggle that with your design in Quartus.
KDS_Manikanta
Okay, Thanks for the response
As I'm trying the same where input clock is assign for two output signal(q1, q2)
One is q1 rooted to HSMC GPIO, another is q2 rooted to PMODA
Here q2 signal I can see the output pulse of clock through oscilloscope
Where q1 signal which is of HSMC GPIO pin assigned...I didn't get the pulse. Whether am I missing something to check the output correctly?
q1 <= clk; -- pin planner y7
q2 <= clk; -- pin planner c7 (for reference)
Please find the attachment of workspace, kindly acknowledge the response
Thanks & Regards,
Kothapalli Dora Sai Manikanta
YuanLi_S_Intel
Can you try on the other pin HSMC GPIO pin? Also, check or probe the CLK pin and see whether it has output?
KDS_Manikanta
yes, I tried probing the CLK pin to another HSMC GPIO pin, I can't see CLK pulse in another pin too...!
YuanLi_S_Intel
I think you have to connect correctly all the input and output to guarantee the function. Please take a look at the user guide.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-max10m50-fpga-dev-kit.pdf#page=52
