Hi..
Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/100 is good enough, i don't need high speed.) So i just take CycloneIII's example (from its development kit) as a reference for the SOPC and follow the manual of TSE. Also I add a redundunt reset circuitry for this enet_reset since there is a certain issue on this kind of setup which i got from this forum. However, it never worked. Symton is as follows.. BTW i use Simple socket server on NIOSII and Quartus8.0 SOPC. PHY can receiver packet (it seemed.. because i can see RX LED is blinking when i tried 'ping').. but no Tx ( i never see TX LED blinking.) Also i set a break point on SGDMA rx int.. it never asserted. So i guessed TSE_MAC never receives data from PHY. I know there should be some tools which could verify something for me.. Sorry.. I'm a newbid in Altera FPGA. So if you think there is anything i should check or modify.. Please let me know. Of course, if you make it work before, could you please share that with me? Thanks.Link Copied
First you need to check that the PHY didn't auto-negotiate a 1Gbs link. Because in that case if you try to use the MII interface it won't work.
Then you can add some Signal Tap probes to see what signals are coming from the PHY it should help you understand why the MAC doesn't process them.- Mark as New
Thanks for the reply.
I was connecting the ethernet cable into 10/100 router and i gounded set_1000 to make sure it's not running on Gigabit. Also i checked the LED indicator with the right ethernet mode indication. For the Signal Tap, I will try it right away. BTW, i happened to see some threads mentioning about timing constraints on TSE_MAC related signals. Do you think that's very likely apply in my case. I believe I didn't touch that at all..:(- Mark as New
You definitively need to constrain the I/O signals on the MII bus. It could explain your problem.
Hi.. Help!!
I've tried to do the time constaints on all tse_mac related signals (following tse_mac_constraints.sdc) and i can get the report of the time request without any negative slack in all models. However, after i loaded the image on the board, it's still about the same thing. In 10/100 mode (GMII/MII), only RX LED is on, and never see TX LED lit. I also tried RGMII mode, and followed the timing scripts you mentioned in the other thread. Fortunetely, i can see both RX and TX LED lit. However, the data still can't get through.. (but i think its situation is better than MII mode) So my question is do i have to follow that sample timing scripts which you provide (like chaning 125MHz to 25MHz for Ethernet 100 mode)? Or i miss something here? (maybe i should have Marvell PHy spec and follow its recommendaton for the time constraints) BTW, the timing script:# **************************************************************# Create Clock#**************************************************************create_clock -name {clkin_125} -period 8 [get_ports {clkin_125}]create_clock -name {enet_rx_clk} -period 8 [get_ports {enet_rx_clk}]#**************************************************************# Create Generated Clock#**************************************************************derive_pll_clocksset enet_tx_in_clk gbe_pll:inst12|altpll:altpll_component|gbe_pll_altpll:auto_generated|wire_pll1_clk[0]set enet_tx_out_clk gbe_pll:inst12|altpll:altpll_component|gbe_pll_altpll:auto_generated|wire_pll1_clk[1]#**************************************************************# Set Input Delay#**************************************************************set_input_delay -clock enet_rx_clk -min 1.5 [get_ports {enet_rxd [*] enet_rx_dv}] -add_delayset_input_delay -clock enet_rx_clk -max 2.5 [get_ports {enet_rxd [*] enet_rx_dv}] -add_delayset_input_delay -clock enet_rx_clk -clock_fall -min 1.5 [get_ports {enet_rxd [*] enet_rx_dv}] -add_delayset_input_delay -clock enet_rx_clk -clock_fall -max 2.5 [get_ports {enet_rxd [*] enet_rx_dv}] -add_delay#**************************************************************# Set Output Delay#**************************************************************set_output_delay -clock $enet_tx_out_clk -max 1 [get_ports {enet_txd [*] enet_tx_en}]set_output_delay -clock $enet_tx_out_clk -min -1 [get_ports {enet_txd [*] enet_tx_en}] -add_delayset_output_delay -clock $enet_tx_out_clk -clock_fall -max 1 [get_ports {enet_txd [*] enet_tx_en}] -add_delayset_output_delay -clock $enet_tx_out_clk -clock_fall -min -1 [get_ports {enet_txd [*] enet_tx_en}] -add_delay#**************************************************************# Set Clock Groups#**************************************************************set_clock_groups -exclusive -group [get_clocks {clkin_125 enet_tx_in_clk enet_tx_out_clk}] set_clock_groups -exclusive -group [get_clocks {enet_rx_clk}]# **************************************************************# Set False Path#**************************************************************set_false_path -from [get_ports {enet_mdio}]set_false_path -to [get_ports {enet_mdc enet_mdio}]set_false_path -setup -rise_from $enet_tx_in_clk -fall_to $enet_tx_out_clkset_false_path -setup -fall_from $enet_tx_in_clk -rise_to $enet_tx_out_clkset_false_path -hold -rise_from $enet_tx_in_clk -rise_to $enet_tx_out_clkset_false_path -hold -fall_from $enet_tx_in_clk -fall_to $enet_tx_out_clk#**************************************************************# Set Multicycle Path#**************************************************************set_multicycle_path -from $enet_tx_in_clk -to $enet_tx_out_clk -setup -start 2#**************************************************************# Set Maximum Delay#**************************************************************set_max_delay -from $enet_tx_out_clk -to [get_ports {enet_gtx_clk}] 20#**************************************************************# Set Minimum Delay#**************************************************************set_min_delay -from $enet_tx_out_clk -to [get_ports {enet_gtx_clk}] 0- Mark as New
IIRC the Altera TSE mac doesn't work very well with RGMII at 10/100 speeds, so you should stick to MII. The constraints will need some adjustments as you are not in DDR anymore.
Did you try to connect SignalTap probes to the MII signals to check if anything is received on that side?- Mark as New
Hi.. Daixiwen,
Thanks for your reminding again. I use SignalTap to check the signals and found out that enet_rx_clk and enet_tx_clk were not moving at all.. I think that's the reason i didn't see any rx data or tx data. However, what's the reason to make them like this? Since i can talk to PHY through MDIO.. is that my design problem? Just don't understand why.. I follow almost everything from the standard example of cyclone III. Can you give me some suggestions? BTW i attached the start up log here for simple socket server. Thanks again for your help. ****************************************************** nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.1 Copyright 1996-2007 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:ff:49:00 prepped 1 interface, initializing... [tse_mac_init] SGDMA desc memory cleared INFO : TSE MAC 0 found at address 0x00001c00 INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : Applying additional PHY configuration of Marvell 88E1111 INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Gigabit = 0, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created IP address of et1 : 192.168.50.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)- Mark as New
Can you post your top level HDL file? We might be able to quickly determine if you've got something wrong.
Also, as a first step, I would recommend double-checking all of your pin assignments that connect to the MAC. Is this a custom board or are you using a development kit? Jake- Mark as New
TO_BE_DONE
The ethernet tx clk comes from the PHY when using MII, or comes from the FPGA when using GMII. So in your case both rx and tx clocks should be inputs.
Did you double check the assignments for these two pins? Are they inputs, with the correct I/O standard? Are they connected to the correct pins of the PHY on your board?- Mark as New
Yup.. I have double-checked the pin assignment and they matched exactly the same as shown in reference manual of Stratix III.
Also i don't need to make any changes on pin assignment because i use the standard example from Stratix III. It's there from the beginning. BTW, I'm wondering about that wierd reset issue with on-board Marvell PHY.. For this reset circuitry, i was following an example posted on this forum, however i checked its delay between user_resetn and enet_resetn is quite long according to his design.. Could this be an issue here?- Mark as New
I don't think so... as long as the reset pulse is larger than Marvell's specification it should be fine. And if you can communicate with your PHY's MDIO, I would say that the initialization went fine.
Can you check with an oscilloscope the clock signals from the PHY? It should tell you if the problem is in the FPGA or outside.- Mark as New
I was thinking about that too.. If that's the reason, i can have a break here.
However, after i borrowed one ossiloscope and checked that 25Mhz crystal output, unfortunetely it's there.. so the problem should be coming from FPGA? Any suggestions?- Mark as New
I'm starting to be out of suggestions ;)
Can you check the enet_rx_clk and enet_tx_clk signals with your oscilloscope? It may be a bit tricky to catch with BGA's though...- Mark as New
Thanks for the reply:)
I've already started to ask help from FAE. (I suspected there is hardware issue as well.) Hopefully they can come out with something soon. Will update u soon.- Mark as New
Please post any resolution you get on this issue. We seem to be stuck near the same point.
-Art- Mark as New
Finally get it work with the support from FAE.. Just want to mention that design should be pretty straight-forward as specified on other threads. Two things are more critical.
1. timing constraints.. (it's less critical than 2.) 2. MDIO programming to reset PHY.. this is a must to make Stratix III board's Phy starting to work. Also rx and tx clocks won't start until you do the follows. I just provide the patch as follows.. please add the following lines at 1233 of altera_avalon_tse.c.. you should be able to locate this file under altera\80\ip\triple_speed_ethernet\lib\sopc_builder\altera_triple_speed_ethernet\HAL\src /***********************************/ if ((is_phy_in_profile == 1) && (oui == 0x5043) && (phyadd == 0x12)) {# ifdef STRATIX_III_3S150_GMII//switch to GMII mode alt_tse_phy_wr_mdio_reg(pphy, 27, 0, 4, 0xf);// switch to GMII mode alt_tse_phy_wr_mdio_reg(pphy, TSE_PHY_MDIO_CONTROL, TSE_PHY_MDIO_CONTROL_RESET, 1, 1);//reset PHY while ((alt_tse_phy_rd_mdio_reg(pphy, TSE_PHY_MDIO_CONTROL, TSE_PHY_MDIO_CONTROL_RESET, 1)) != 0); //wait reset complete# endif # ifdef Stratix_III_3S150_SGMII//switch to SGMII mode alt_tse_phy_wr_mdio_reg(pphy, 27, 0, 4, 0x0);// switch to SGMII mode alt_tse_phy_wr_mdio_reg(pphy, TSE_PHY_MDIO_CONTROL, TSE_PHY_MDIO_CONTROL_RESET, 1, 1);//reset PHY while ((alt_tse_phy_rd_mdio_reg(pphy, TSE_PHY_MDIO_CONTROL, TSE_PHY_MDIO_CONTROL_RESET, 1)) != 0); //wait reset complete# endif } Hopefully this can help you to bring your own Stratix III board..- Mark as New
hi, i think i have a quite similar problem to my stratix II gx. where can i find code to my board?
i can't find any macro called " Stratix_III_3S150_SGMII " in my pc, i have a stratix 2 GX, what macro i should use?
Hey.. man,
Just add a definition in the header of file yourself to make the macro alive. Just make sure which mode you want to turn it on. Leon.- Mark as New
--- Quote Start --- Finally get it work with the support from FAE.. Just want to mention that design should be pretty straight-forward as specified on other threads. Two things are more critical. 1. timing constraints.. (it's less critical than 2.) --- Quote End --- Thanks Leon. Would you mind posting your timing constraints? I'm trying to use GMII interface (Marvell Phy, StratixIII devkit, tse IP), but I'm having a real hard time figuring out what the constraints need to be. -Brian
