Hi INTEL Team,
This is Siddesh from Flex Component Engineering Team.
We are working on some of your manufacturing parts and require information on the below.
Could you please provide below MPN details as quick as possible as it's an urgent request from our site.
End Customer: ALCATEL-LUCENT
Flex Manufacturing Site: Gaud South (Mexico)
ITEM NUMBER: ALC5H-32-0477-04
MPN_DESCRIPTION: FPGA,10AX115SXF45I2SG,ARRIA 10
MANUFACTURER PART NUMBER (MPN): 10AXF45GAA
1. ABOVE DESCRIPTION MATCHES WITH MPN (YES/NO) ?:
2. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?:
3. IS THIS PART AVAILABLE IN TAPE & REEL PACKAGING OPTION (YES / NO) ?:
4. PROVIDE US CORRECT & ORDERABLE PART NUMBER ?:
5. LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ?:
6. IF NRND, PLEASE US PROVIDE LTB AND LTS DATE ?:
7. IF OBSOLETE, SUGGEST US EXACT DROP-IN REPLACEMENT WITH SAME FFF?:
8. IF OBSOLETE, PLEASE SHARE WITH US PCN DOCUMENTS ?:
9. MOUNTING TYPE: SMT (SURFACE MOUNT TECHNOLOGY) (YES / NO) ?:
10. MOISTURE SENSITIVITY LEVEL (MSL) ?:
11. PART MARKING ?:
12. PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?:
13. ROHS COMPLIANT (YES / NO) ?:
14. DATASHEET LINK // DATASHEET IN PDF // SPECIFICATION SHEET // DRAWING SHEET:
Looking forward to your quick response.
Note:-
• MSL: The MSL is the MOISTURE SENSITIVY LEVEL of the material. There are some levels that manifest the amount of time and the humidity that the material can handle before baking it.
• Part Marking: It is the printed marking on the top side of a part. For example, it may contain date code, country of assembly, manufacturer logo, etc. Part marking/Top Marking is the unique code mentioned on the device to identify the part details.
• NRND: Not recommended for New Design
• LTB: Last Time Buy Date
• LTS: Last Time Shipment Date
• SMT: Surface Mount Technology
• FFF: Form, Fit and Function
SIDDESH CHAVAN
siddesh.chavan@flex.com
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
Hi @NazrulNaim_Intel ,
Thank you for confirmation.
Could you please confirm me Requested Parts Information ? Please confirm me this.
SIDDESH CHAVAN
10AX115SXF45I2SG seems to be an invalid part number. I think the “X” highlighted in red is incorrect, should be a number for the speed grade. Can you please clarify this again.
Thank you.
Nazrul Naim
A Friendly Reminder..!!!
Is there any update on requested part Information from your Technical Team ?
Please support me on this as it's pending from days.
Our Correct Manufacturing Part Number should be 10AXF45GAA, Not this one 10AX115SXF45I2SG.
If our Source MPN is INVALID Part Number, Please provide us Correct Part Number to Order.
Also, Share with us Datasheet Link / Datasheet in PDF for requested Part Number and other Information which I ask below.
11. PART MARKING ?:
SIDDESH CHAVAN
Thanks for response.
11. PART MARKING ?:
SIDDESH CHAVAN
I'm still in the midst of the discussion regarding this with the internal teams in searching for the owner of the design . Unfortunately, it takes longer than usual heard
I will plan on letting you know as soon as I learn more information. Really appreciate your patience.
Warm Regards,
Nazrul Naim
Below is the answer for your enquiry.
1. ABOVE DESCRIPTION MATCHES WITH MPN (YES/NO) ?: YES
2. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?: ORDERABLE
3. IS THIS PART AVAILABLE IN TAPE & REEL PACKAGING OPTION (YES / NO) ?: -
4. PROVIDE US CORRECT & ORDERABLE PART NUMBER ?:-
5. LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ?: ACTIVE
6. IF NRND, PLEASE US PROVIDE LTB AND LTS DATE ?:-
7. IF OBSOLETE, SUGGEST US EXACT DROP-IN REPLACEMENT WITH SAME FFF?:-
8. IF OBSOLETE, PLEASE SHARE WITH US PCN DOCUMENTS ?:-
9. MOUNTING TYPE: SMT (SURFACE MOUNT TECHNOLOGY) (YES / NO) ?: YES
10. MOISTURE SENSITIVITY LEVEL (MSL) ?: LEVEL 3
11. PART MARKING ?:-
12. PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?: TRAY
13. ROHS COMPLIANT (YES / NO) ?: YES
14. DATASHEET LINK // DATASHEET IN PDF // SPECIFICATION SHEET // DRAWING SHEET: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.p...
Nazrul Naim
Thank you for response & Appreciate for your support.
Just a question for you, Can you confirm me Part Marking for this MPN: 10AXF45GAA ?
Part Marking is the Device Code Marking / Top Mark which is printed on Top-Side of the Device and used as identification code.
Please reply with your confirmation comment.
SIDDESH CHAVAN
Sorry to let you know that, we do not provide part marking verification in order to avoid the devices from grey market.
Intel PSG has its authorized distributor to sale Intel devices. If you got the devices from formal distributors, you shouldn’t worry on the device authenticity/validity as the devices must be valid units. Otherwise, we do not ensure the device quality and do not provide the further service. You may find the authorized distributor list from the link below:
https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
