USB Blaster Test.. (Device)
1. Altera USB Blaster (Black, PL-USB2-BLASTER)
2. Terasic USB Blaster
3.ALTERA USB Blaster ByteBlaster II
Target : 10CL080... (Cyclone 10 LP)
Computer : Windows10, 64Bit
Quartus 17.1 lisenced Ver.
4. Using Programmer puts the target "*.sof" and Start (Not timelimited sof)
5. Check the Progress (100%) @ Programmer
6. @ Eclipse - Run Configuration -> Nios II Hardware -> Targer Connection -> Refresh Connections)
Step 4 : 1,2,3 Devices works well
Step 5 : 1,2,3 Devices 100% download
Step 6 : 2,3 Device works well But..
Only 1 Device got problem (No Nios II Target Connection Paths were Located. Check Connections and that a nios II .sof downloaded)
Test Step
Device 1(N.W) -> Device2 (W.W)-> Device 3 (W.W) -> Device 1(N.W)
N.W : Not work
W.W : Works Well
USB Blaster Quite Expensive Over $200 but doesn't works well for me. Is that any way?
Hi. @AhmedH_Intel Already Checked..
Ignore mismatched system ID.
Ignore mismatched system Timestamp
and.. without Marking.. .. "System ID Checks" .. Mark or didn't mark. ,
When "Click Refresh Connections", Have to shown somethings at "Connections→Processors Some.."
checking System ID is Next Step.
1, sof
2, refresh connections -> "Connections→processors"
3, Select preocessor, if you are Multi Processor..
4, Byte Stream Devices → Select , if you add more than 2 "JTAG UART"
5, then Mark, un-Mark System ID..
In my case using "PL-USB2-BLASTER" Below Pics.. "Refresh Connections" click more than 10 times , and Resolve Names. clock lots of times..
but doesn't works. just Error message
→ "no Nios II taget connection pathes were located. Check connections and that a Nios OO .sof is downloaded"
Hi Jongyun,
Sorry for the delay, Can you please check another USB blaster, I have the C10-LP and it is working fine.
If you agree you can share a sample design with me to try it on my board.
