6157 Discussions
USB Mass storage device - Save data to file
antonto
Hello,  I have DE10-Lite board and I'm using Quartus Prime Lite Edition.
My goal is to run something on the board and i want the output to be saved in a txt file.
My code is correct...I think but it doesnt seem to write something on the file. I've done some research and i found out that i need to configure the usb  to mass storage device, please correct me if my wrong.
This is my code for a simple 2 to 1 mux just to make sure i get it right.
module test99(
input wire a,
input wire b,
input wire s,
input wire clk,
input wire file_enable,
output wire y
// Mux logic
assign y = s ? a : b;
// register to hold the data to be saved
reg [15:0] data_to_save;
// Initialize the data
initial begin
data_to_save = 16'h1234;
end
// Save data to a text file when file_enable is high
always @(posedge clk) begin // Use the clock signal
if (file_enable) begin
$fopen("output.txt", "w"); // Open the file for writing
$fwrite("output.txt", "Output (y) is: %b", y); // Write data to the file
$fclose("output.txt"); // Close the file
end
end
endmodule
and this is on my top module that was created by the program, so i dont need to go to the pin planner, i just call my module from there.
test99(.a(SW[0]),.b(SW[1]),.s(SW[2]),.clk(MAX10_CLK1_50),.file_enable(SW[3]),.y(LEDR[0]));
I have created the file output.txt and saved it in the same folder.
ShengN_Intel
Probably that'll be easier by looping back the data and writing into text file using python.
Sheng
sstrell
This is not synthesizable code for an FPGA.  An FPGA on its own has no concept of a file system.  This would work for a simulation but not synthesis.
You could save data to an on-chip RAM and then output it in some way or you could add a processor like Nios V, run an OS, and have drivers to access external mass storage.
But as your code is right now, it won't save to a file.
antonto
It definitely wont. I actually got a idea, please tell me what do you think about it. My project is basically to combine two boards, the DE10-Lite  and SAMD21 M0. The SAMD21 board will send the inputs to the DE10-Lite which will do something and the goal was to save the output to a txt file. But now im thinking if i send the output back to the SAMD21 and then save it to a txt file wouldn't that be easier?
Will try to do some testing and tell you the results.
ShengN_Intel
The Verilog File IO Operations usually being used/worked for testbench check this link https://www.chipverify.com/verilog/verilog-file-io-operations
If you want to run something on the board and output to be saved in a txt file, probably need to use embedded system. Here is a video link for your reference https://www.youtube.com/watch?v=kbIcXwtfBiY&t=414s
Sheng
antonto
Thank you for your response, i saw the video that you sent me and it was actually quite good I didnt know that you could do that. Sadly it uses C and i can only use python and SystemVerilog on my project. My project is basically to combine two boards, the DE10-Lite  and SAMD21 M0. The SAMD21 board will send the inputs to the DE10-Lite which will do something and the goal was to save the output to a txt file. But now im thinking if i send the output back to the SAMD21 and then save it to a txt file wouldn't that be easier? Please tell me your opinion and will keep you updated after i do some testing.
ShengN_Intel
Sheng
antonto
Sorry for answering so late. Yes it worked with looping the data back to the samd21 and writing in there in a file. Thanks again for your time guys.
