6387 Discussions
Ubuntu on terasic DE-1 SOC help needed
hi all
im new in the SOC world :)
i got a terasic DE1-SOC board and i want to run Ubuntu on it.
i downloaded the ubuntu SD card IMGE file from terasic and flash it on a new 8GB SD card.
i inserted the SD card to the board and turn the board on
ubuntu is up but when i plug the internet cable to RJ45 connector i don't have an internet access ( the green led is off and the yellow is on )
can some one help me to make the Ethernet work?
also i want to know if there is a newer virsion of ubunu(like 14.0 ) that can run on DE1-SOC ? (i be glad for a link to the image file)
thanks for the help :)
Hi there,
I understand that it's been a while and you've probably figured it out by yourself or sent a mail to our support team already, but in case the problem is still there, could you provide the serial number onboard, so we can start working on it together ?
David from Terasic
agree with David....... !!!
