6400 Discussions
Using DE10-nano GPIO1/GPIO0 from Linux
jackhab
I’m trying to use GPIO on DE10-nano evaluation board connectors JP1/JP7. From documentation I assumed these IOs directly accessible from HPS.
However, by using various demo C code I only managed to access user LED which also blinks under control of the FPGA. The rest of GPIO remain in high-Z (1.6V).
I also tried to operate GPIOs via /sys/class/gpio interface. After exporting all available numbers I have gpio427 to gpio511 directories under /sys/class/gpio. But still writing to gpioX/direction and gpioX/value files has no effect on the lines on JP1/JP7.
Do I have to configure anything else before accessing GPIO from HPS?
EBERLAZARE_I_Intel
Have you run though the "Example for HPS SoC" in the DE10-nano user manual in Chapter 6?
Regards.
jackhab
I finally got it running after I found out the GPIO on JP7 connector are mapped in Linux starting at number 107.
EBERLAZARE_I_Intel
Great, please let me know if there is any more problem that you encounter or any questions you want to ask. Thanks.
