5784 Discussions
Using PCI Express on Linux with DE10-Pro-GX-280-4G (Stratix 10)
MMate10
I'm trying to run demonstrations distributed with the DE10-Pro board on a Linux system. I have Quartus Pro 19.2 installed. I'm doing the following:
a) Run Demonstrations/PCIe_DDR4/demo_batch/test.sh, it successfully programs the board.
b) Soft-reboot the computer. Now I've got the following entry in lspci output:
83:00.0 Non-VGA unclassified device: Altera Corporation Device e003 (rev 01)
I have the following in dmesg:
[ 1.527793] pci 0000:83:00.0: [1172:e003] type 00 class 0x000000 [ 1.527820] pci 0000:83:00.0: reg 0x10: [mem 0x00000000-0x000001ff 64bit pref] [ 1.527843] pci 0000:83:00.0: reg 0x20: [mem 0x00000000-0x07ffffff 64bit pref] [ 1.527858] pci 0000:83:00.0: enabling Extended Tags ... [ 1.570379] pnp 00:03: disabling [mem 0x00000400-0x000004ff] because it overlaps 0000:83:00.0 BAR 4 [mem 0x00000000-0x07ffffff 64bit pref] ... [ 1.573414] pnp 00:0d: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:83:00.0 BAR 4 [mem 0x00000000-0x07ffffff 64bit pref]
c) Compile and load the driver in Demonstrations/PCIe_SW_KIT/Linux/PCIe_Driver, and get the following in dmesg:
[ 50.093063] altera_pcie: loading out-of-tree module taints kernel. [ 50.093123] altera_pcie: module verification failed: signature and/or required key missing - tainting kernel [ 50.093492] Altera PCIE: altera_pcie_init(), Aug 5 2019 19:11:18 [ 50.093592] Altera PCIE 0000:83:00.0: can't enable device: BAR 0 [mem 0x00000000-0x000001ff 64bit pref] not claimed [ 50.093669] Altera PCIE 0000:83:00.0: pci_enable_device() failed [ 50.093713] Altera PCIE 0000:83:00.0: goto err_enable [ 50.093751] Altera PCIE 0000:83:00.0: goto err_initchrdev [ 50.093791] Altera PCIE 0000:83:00.0: goto err_bk_alloc [ 50.093894] Altera PCIE: probe of 0000:83:00.0 failed with error -22
d) the /dev/altera_pcie0 device does not show up, running Demonstrations/PCIe_DDR4/demo_batch/linux_app/PCIE_DDR4 fails.
My system is Debian 10 Buster, kernel 4.19.0-5-amd64. The computer is a workstation with two XEON E5 2620 v2.
BoonT_Intel
Hi Sir,
This DE board is develop by third party vendor. I also believe the demo design /PCIe_DDR4/demo_batch/test.sh is from third party.
For the third party issue, please contact the vendor directly for better support.
MMate10
I have found the source of the problem. The third party software was not really an issue - I've created a new project, following the instructions on https://www.intel.com/content/www/us/en/programmable/documentation/sox1520633403002.html - and I had the exact same problem. It turns out that if PCI device and class code are zero, Linux fails to initialize the card for some reason. When I changed device and class codes in my project, the card was detected successfully.
MMate10
Found the problem. Looks like Linux doesn't really like zero PCI device code and class code. When I created a new project with the Avalon-MM Intel Stratix 10 Hard IP+ for PCI Express, with zero PCI device and class code, the problem persisted. With the device and class code non-zero, everything works fine.
BoonT_Intel
Thanks for your sharing. I think it is true that in certain system, we need to enter a non-zero value to device ID and class code. Example, in the S10 platform reference design, we also need to enter a predefined value to the device id and class code.
