6189 Discussions
Using Uboot 2020.04, data read write between HPS to FPGA using LWH2F Bridge access
Ravin11
I am trying read and write data from fpga using uboot application, using Cyclone5 socfpga(DE10 NANO)
Enabled the bridge access (socfpga_bridges_reset(0)) and permod register also programmed the fpga.
Can anyone suggest how to access the fpga register data.
Ravin
JingyangTeh
Hi
To access to the IPs connected through the LWH2F bridge you could us ethe md command.
https://unix.stackexchange.com/questions/120374/memory-display-using-md-in-u-boot
For the LWH2F bridge you would need to start from the address 0xFF200000.
https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1410068170804.html#sfo1410068170804
Jingyang, Teh
