6357 Discussions
(VHDL) Help...I set the timer counter code. I want to reset the circuit by pressing it more than 2 seconds. How do I write code?
zasas
USE ieee.std_logic_unsigned.all;
ENTITY TIMER1 IS
        digit1, digit2, digit3, clk_period: OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END TIMER1;
ARCHITECTURE TIMER1 OF TIMER1 IS
SIGNAL Hzclk : STD_LOGIC;
   SIGNAL s1: INTEGER RANGE 0 TO 10
  SIGNAL s2: INTEGER RANGE 0 TO 6;
SIGNAL minutes: INTEGER RANGE 0 TO 10;
BEGIN
PROCESS (clk)
VARIABLE count : INTEGER RANGE 0 TO fclk;
BEGIN
IF (clk'EVENT AND clk='1') THEN
count := count +1;
IF (count=fclk/2) THEN
 Hzclk <= '1';
ELSIF (count=fclk) THEN
Hzclk <= '0';
count := 0;
END IF;
END IF;
END PROCESS;
PROCESS (Hzclk, rst)
VARIABLE count1: INTEGER RANGE 0 TO 10;
VARIABLE count2: INTEGER RANGE 0 TO 6;
VARIABLE count3: INTEGER RANGE 0 TO 10;
BEGIN
IF (rst ='1'AND ) THEN
after(20ns);
count1 :=0;
count2 :=0;
count3 :=0;
ELSIF (clk'EVENT AND clk='1') THEN
IF (startstop='1' AND (count1/=9 OR count2/=5 OR count3/=9)) THEN
count1 := count1 +1 ;
IF (count1=10) THEN
count1 := 0;
 count2 := count2 + 1;
IF (count2=6) THEN
count2 := 0;
count3 := count3 +1;
END IF;
END IF;
END IF;
END IF;
s1 <= count1;
s2 <= count2;
 minutes <= count3;
END PROCESS;
 PROCESS (s1, s2, minutes)
 BEGIN
CASE s1 IS
WHEN 0 => digit1 <= "11111100";
WHEN 1 => digit1 <= "01100000";
WHEN 2 => digit1 <= "11011010";
WHEN 3 => digit1 <= "11110010";
WHEN 4 => digit1 <= "01100110";
WHEN 5 => digit1 <= "10110110";
  WHEN 6 => digit1 <= "10111110";
  WHEN 7 => digit1 <= "11100000";
WHEN 8 => digit1 <= "11111110";
 WHEN 9 => digit1 <= "11110110";
WHEN OTHERS => NULL;
END CASE;      CASE s2 IS
WHEN 0 => digit2 <= "11111100";
WHEN 1 => digit2 <= "01100000";
  WHEN 2 => digit2 <= "11011010";
  WHEN 3 => digit2 <= "11110010";
   WHEN 4 => digit2 <= "01100110";
  WHEN 5 => digit2 <= "10110110";
END CASE;
CASE minutes IS
 WHEN 0 => digit3 <= "11111100";
 WHEN 1 => digit3 <= "01100001";
 WHEN 2 => digit3 <= "11011011";
 WHEN 3 => digit3 <= "11110011";
 WHEN 4 => digit3 <= "01100111";
  WHEN 5 => digit3 <= "10110111";
  WHEN 6 => digit3 <= "10111111";
  WHEN 7 => digit3 <= "11100001";
 WHEN 8 => digit3 <= "11111111";
WHEN 9 => digit3 <= "11110111";
 END CASE;
  END PROCESS;
  END TIMER1;
AnandRaj_S_Intel
Hi @zasas​
Okay, You have to build a counter which will count to 25 million to get 2 second events which will be used for reset.
You can refer below example and use it in you design.
Please note that I have not checked your code.
PROCESS (Clock) BEGIN IF (Clock'EVENT AND Clock = '1') THEN counter <= counter + '1'; if( counter = <NUMBER>) then --<NUMBER> =How many clocks will you need to get two second? Well it will be clearly 25 million cycles assusing clock of 50MHz. reset<= '1'; counter <= "0"; else reset<= '0'; end if; END IF; END PROCESS;
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
