Hello, I'm writing a verilog prog on my DE1 to read off the flash memory... but I cannot
figure out how I can wait until the read completes before continuing in my program. I set f_read = 1 outside to allow the read to begin we set f_busy = 1 during this time. After 1 ms, we finish up and reset the registers || //50MHz = 20 ns/cycle || always @(posedge CLOCK_50) begin || if (f_read == 1) begin || f_busy <= 1; || || if (f_count == 0) begin || || //set up signals here || || //wait 0.2 ms || end else if(f_count == 1) begin || || //data is now valid, store it || || //wait 1 ms || end else if(f_count == 5) begin || || f_count <= 0; //reset stuff || f_busy <= 0; || end || || if(f_busy == 1) begin || f_count <= f_count+1; || end || end || end So, say I have a task called read_flash. We set f_read in here - what can I put in there to wait for f_busy to equal 0?Link Copied
So I built this... but....
always @(posedge read_flash_pixel or posedge flash_pause_done) begin if (read_flash_pixel) begin flash_pause <= 1; end else begin flash_pause <= 0; end end always @(posedge CLOCK_50) begin if(flash_pause == 1) begin flash_pause_count <= flash_pause_count+1; if (flash_pause_count == 1) begin mod_pixel_addr <= pixel_addr; read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 5) begin pixel_p1 <= save_data; mod_pixel_addr <= (pixel_addr+1'b1); read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 10) begin pixel_p2 <= save_data; mod_pixel_addr <= (pixel_addr+2'b10); read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 15) begin pixel_p3 <= save_data; flash_pause_done <= 1; read_flash <= 0; end end else begin flash_pause_count <= 0; end flash_pause_done <= 0; end I get a latch warning here... and... Error (10200): Verilog HDL Conditional Statement error at RealTime2.v(264): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct always @(posedge read_flash or posedge f_done) begin //trigger read if (read_flash == 1) begin data_addr <= mod_pixel_addr; f_read <= 1; end else begin f_read <= 0; end end- Mark as New
--- Quote Start --- So I built this... but.... always @(posedge read_flash_pixel or posedge flash_pause_done) begin if (read_flash_pixel) begin flash_pause <= 1; end else begin flash_pause <= 0; end end always @(posedge CLOCK_50) begin if(flash_pause == 1) begin flash_pause_count <= flash_pause_count+1; if (flash_pause_count == 1) begin mod_pixel_addr <= pixel_addr; read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 5) begin pixel_p1 <= save_data; mod_pixel_addr <= (pixel_addr+1'b1); read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 10) begin pixel_p2 <= save_data; mod_pixel_addr <= (pixel_addr+2'b10); read_flash <= 0; read_flash <= 1; end if (flash_pause_count == 15) begin pixel_p3 <= save_data; flash_pause_done <= 1; read_flash <= 0; end end else begin flash_pause_count <= 0; end flash_pause_done <= 0; end I get a latch warning here... and... Error (10200): Verilog HDL Conditional Statement error at RealTime2.v(264): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct always @(posedge read_flash or posedge f_done) begin //trigger read if (read_flash == 1) begin data_addr <= mod_pixel_addr; f_read <= 1; end else begin f_read <= 0; end end --- Quote End --- Hi, you have to define what should happend to "data_adder" in the else branch. Kind regards GPL
I'm not a Verilog expert, but I think your problem is with this line:
First of all you have two clocks driving the same process, and this is not a good coding practice. Then, one of the clocks (read_flash_pixel) is also used in the conditional inside the process: the error message seems to refer to this. I'd use the always @(posedge CLOCK_50) for this process, too. Every clock cycle you can store read_flash_pixel and flash_pause_done levels and in the next one you test the edge condition.
Cool! I ended up using the negedge CLOCK_50 so it gets done before the next clock cycle on the next step of the setup :-) that seems to work nicely :D
--- Quote Start --- I'm not a Verilog expert, but I think your problem is with this line: always @(posedge read_flash_pixel or posedge flash_pause_done) First of all you have two clocks driving the same process, and this is not a good coding practice. Then, one of the clocks (read_flash_pixel) is also used in the conditional inside the process: the error message seems to refer to this. --- Quote End --- To clarify this point. It's legal Verilog syntax, not involving two clocks. But I guess, it's not what the original poster wanted, he may have misunderstood this common Verilog construct himself. read_flash_pixel is not a clock, if it's used together with if (read_flash == 1), it's an asynchronous input. The respective VHDL code is
process(read_flash_pixel , posedge f_done);
begin
if read_flash_pixel = '1' then
elsif rising_edge(posedge f_done) then
end if;
end process;
I think, it's useful to know the basic constructs of a "foreign" language, otherwise you can't read the code.
Topic Options
