Verilog delays~?
Hello, I'm writing a verilog prog on my DE1 to read off the flash memory... but I cannot
figure out how I can wait until the read completes before continuing in my program.
I set f_read = 1 outside to allow the read to begin
we set f_busy = 1 during this time.
After 1 ms, we finish up and reset the registers
|| //50MHz = 20 ns/cycle
|| always @(posedge CLOCK_50) begin
|| if (f_read == 1) begin
|| f_busy <= 1;
|| if (f_count == 0) begin
|| //set up signals here
|| //wait 0.2 ms
|| end else if(f_count == 1) begin
|| //data is now valid, store it
|| //wait 1 ms
|| end else if(f_count == 5) begin
|| f_count <= 0; //reset stuff
|| f_busy <= 0;
|| end
|| if(f_busy == 1) begin
|| f_count <= f_count+1;
|| end
|| end
|| end
So, say I have a task called read_flash. We set f_read in here - what can I put in there to wait for f_busy to equal 0?
So I built this... but....
always @(posedge read_flash_pixel or posedge flash_pause_done) begin
if (read_flash_pixel) begin
flash_pause <= 1;
end else begin
flash_pause <= 0;
end
end
if(flash_pause == 1) begin
flash_pause_count <= flash_pause_count+1;
if (flash_pause_count == 1) begin
mod_pixel_addr <= pixel_addr;
read_flash <= 0;
read_flash <= 1;
end if (flash_pause_count == 5) begin
pixel_p1 <= save_data;
mod_pixel_addr <= (pixel_addr+1'b1);
read_flash <= 0;
read_flash <= 1;
end if (flash_pause_count == 10) begin
pixel_p2 <= save_data;
mod_pixel_addr <= (pixel_addr+2'b10);
read_flash <= 0;
read_flash <= 1;
end if (flash_pause_count == 15) begin
pixel_p3 <= save_data;
flash_pause_done <= 1;
read_flash <= 0;
end
end else begin
flash_pause_count <= 0;
end
flash_pause_done <= 0;
end
I get a latch warning here... and...
Error (10200): Verilog HDL Conditional Statement error at RealTime2.v(264): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct
always @(posedge read_flash or posedge f_done) begin
//trigger read
if (read_flash == 1) begin
data_addr <= mod_pixel_addr;
f_read <= 1;
end else begin
f_read <= 0;
end
end
--- Quote Start ---
flash_pause <= 1;
end else begin
flash_pause <= 0;
end
end
read_flash <= 0;
read_flash <= 1;
read_flash <= 0;
read_flash <= 1;
read_flash <= 0;
read_flash <= 1;
read_flash <= 0;
end
end else begin
end
end
//trigger read
f_read <= 1;
end else begin
f_read <= 0;
end
end
--- Quote End ---
you have to define what should happend to "data_adder" in the else branch.
Kind regards
GPL
I'm not a Verilog expert, but I think your problem is with this line:
First of all you have two clocks driving the same process, and this is not a good coding practice.
Then, one of the clocks (read_flash_pixel) is also used in the conditional inside the process: the error message seems to refer to this.
I'd use the always @(posedge CLOCK_50) for this process, too.
Every clock cycle you can store read_flash_pixel and flash_pause_done levels and in the next one you test the edge condition.
Cool! I ended up using the negedge CLOCK_50 so it gets done before the next clock cycle on the next step of the setup :-) that seems to work nicely :D
--- Quote Start ---
First of all you have two clocks driving the same process, and this is not a good coding practice. Then, one of the clocks (read_flash_pixel) is also used in the conditional inside the process: the error message seems to refer to this.
--- Quote End ---
To clarify this point. It's legal Verilog syntax, not involving two clocks. But I guess, it's not what the original poster wanted, he may have misunderstood this common Verilog construct himself.
read_flash_pixel is not a clock, if it's used together with if (read_flash == 1), it's an asynchronous input. The respective VHDL code is
process(read_flash_pixel , posedge f_done); begin if read_flash_pixel = '1' then -- elsif rising_edge(posedge f_done) then -- end if; end process;
I think, it's useful to know the basic constructs of a "foreign" language, otherwise you can't read the code.
