Board : cyclone V
I am new to VHDL, I created a 1 port ram through IP integrator, And able to store some value in it, Now I want to access that data in Linux running on HPS using PYTHON. Is it possible.? and where I can get documentation regarding that.?
Yes it is possible.
Were you able to boot the preloader, uboot and also into Linux?
Firstly, I recommend that you check out Rocketboards.org (Get Started) on how to boot the device and eventually run Linux on your Cyclone V SoC board.
You may also use the pre-built image here: https://rocketboards.org/foswiki/Documentation/GSRD180ReleaseNotes#Release_Contents
Do you have any follow up from your side?
